Belt Squeal 4.0 - JeepForum.com
post #1 of 2 Old 10-08-2008, 11:40 AM Thread Starter
200KGrand
Belt Squeal 4.0
I installed a new belt in my WJ and it is sqealing intermittently. It will occur during idling, sometimes when accelarting, other times when engaging the AC and sometimes not at all.
Is this due to a loose belt? I had the belt changed at Goodyear when they did some additional work and they say the belt is automatically tensioned. Elsewhere in these forums, people say that you can manually increase the tension, and it should go away.
Is it due to the tension, or is it simply a cheap belt?
Thanks
200KGrand is offline
post #2 of 2 Old 10-08-2008, 01:40 PM
KeeptheJeep
Thanks
Your water pump may be squealing or an idler.
KeeptheJeep is offline
WJ 4.7 belt squeal? tufmar ZJ Grand Cherokee Forum 8 07-31-2016 11:12 AM
belt squeal - after 2 belts alivenkickin28 ZJ Grand Cherokee Forum 35 03-16-2012 06:11 PM
Obnoxious Belt Squeal after Replacement ddeadserious ZJ Grand Cherokee Forum 16 04-23-2009 10:26 PM
Belt squeal on 4.7 HurriJeff WK Grand Cherokee & XK Commander Forum 3 02-17-2008 07:13 AM
Squeal on start up, not the belt CruiserClass ZJ Grand Cherokee Forum 1 01-09-2008 06:14 PM
