Belt Slipping - JeepForum.com
post #1 of 6 Old 01-04-2017, 06:10 AM Thread Starter
Para32
Belt Slipping
1998 ZJ with the 4.0L
Seems like every time it rains or sometimes in snow the drive belt slips. I say this because the ammeter on the dash dips from 14 V (normally its painted on the dash straight up at 14 V). Also, its pretty stock and I doubt any guards or shrouds are missing. In dry weather its fine.
Question: Will tightening the belt a bit help this problem or is this something that happens to a ZJ with the straight 6 ??
Para32 is offline
post #2 of 6 Old 01-04-2017, 08:34 AM
jeepjeepster
No, its not something that just happens.
Have you checked to see if the belt is tight? Maybe it needs a new belt...
Mine has a very slight squeak to it when I first start it if its been raining. It goes away after a few seconds and causes no other issues, so I leave it be. I would rather it be as loose as possible and cause no issues than to be over tight and wear out the bearings.
1994 ZJ-I6 w/216,000 mi
1998 ZJ 5.9 w/65,155 mi Slate Black
2004 KJ w/90,300 mi
jeepjeepster is offline
post #3 of 6 Old 01-04-2017, 08:37 AM
GOLDWING
I think that it may not be a belt problem. Have you ever cleaned your grounds in the engine bay? There are 2 on the passenger fender, 1 at the coil mount, and another near the dipstick.
GW
2 '98 4.0 ZJs
Hers is stock, mine, BB, Aussie, 2x6 sliders, 31s, etc.
GOLDWING is offline
post #4 of 6 Old 01-04-2017, 09:38 AM
zjosh93
It doesn't do that on my 93. Couple thoughts:
Could be an old worn-out belt and it's marginal most of the time so a little moisture makes it slip.
Could be that you use your headlights and wipers and maybe the heater in the rain/snow so you're voltage would naturally dip somewhat.
I've gotten my belt soaking wet during engine cleaning and it slips but not for long. If your running consistently less voltage in the wet, the water would need to be fairly constantly getting on the belt to make it slip constantly.
zjosh93 is offline
post #5 of 6 Old 01-04-2017, 12:41 PM
mslevin
Doesn't the 4.0 have a similar mechanical tensioner to the 5.2? Is it possible to tighten the belt manually as mentioned in the first post?
Replacing belts is pretty simple and not that expensive. If your belt is at all worn thats the first thing I'd do.
1993 Grand Cherokee Laredo
3.5" IRO lift, 31" Treadwright Wardens
mslevin is offline
post #6 of 6 Old 01-04-2017, 03:43 PM
zjosh93
The 4.0, at least in the ZJ, uses a threaded tensioner. It isn't spring loaded like the 5.2.
zjosh93 is offline
