Belt not turning - JeepForum.com
post #1 of 2 Old 04-09-2011, 12:47 AM Thread Starter
Tuttlebot
1994 FSJ Cherokee
Belt not turning
1994 Grand Cherokee Limited. 6cyl., 113,000 miles.
My daughter was driving the Jeep and the power steering stopped working as well as loud bubbling sound.
I checked it and found no major leaks, fluid levels normal, no overheating. I was about to call in the professionals when I noticed (DUH) that the belt was not turning.
It is holding power and cranks up easily. the belt and fan is not running. I pulled the belt with my hand and it moves fairly easily. It looks intact and solid - it had no fraying, rips or major wear apparent.
So. that about sums up what I have found. I am beyond any ability I have and am definitely not blessed with much mechanical ability.
Any thoughts?
Tuttlebot is offline
post #2 of 2 Old 04-09-2011, 04:06 AM
newfieZJ
You need to pull the belt and find out which pulley isn't turning . You may be able to start it and see which pulley isn't turning too , but , not good for the belt . The belt should be inspected off the jeep now anyways , you may have a worn spot on it .
Bubbling sound is the water/coolant boiling . You may not have overheated to cause this , but darn close . Find the issue and fix it before driving , or , you will end cooking your engine
newfieZJ is offline
power steering , serpentine belt
4wd turning TrevorJeepin ZJ Grand Cherokee Forum 12 07-13-2010 11:44 PM
Water Pump and Belt/Belt Tensioner pilitusf ZJ Grand Cherokee Forum 2 07-04-2009 05:01 AM
02 WJ - Key not turning fin88 ZJ Grand Cherokee Forum 9 11-30-2008 11:57 PM
Lights turning on and off? justin02 ZJ Grand Cherokee Forum 1 05-02-2008 05:22 AM
turning left... bullit_rider ZJ Grand Cherokee Forum 1 05-18-2007 01:23 PM
