#1 | |
BB update
So I went at it today and basically tried to do it with no instructions, and going by what i read on the forums, well didnt go so hot. Finally went to kor.com and got the write up and had to re do a lot of steps and as i got everything off, shocks, sway bar link, and the coil clip, the spring compressors snapped. So me and my dad tried it 4 more times and finally had a pipe wrench help out and got one side in. Tomorrow gonna do the driver side. How hard are the rears?
Alonzo "Casper" Gonzalez 1993 Jeep Grand Cherokee Laredo 4.0L Engine w/ 231 TC IRO 4.5" Lift on Kumho 31" MT
IRO frnt adj. track bar w/ mount Bilstein 5150 shocks JKS Quick Disconnects JCR 1 Ton steering Addco Front Sway bar Flowmaster muffler K&N air filter 2 Pro Comp 2 KC lights on KOR light bar Coleman roof rack Coming Soon! Gears and locker! |
#2 |
Mr. Hyde!
Think about all the tricks you learned today, they'll all make the rear go faster. Likewise after you play with your suspension a few more times you'll be a pro
'04 WJ, 6" Clayton LA's, 242 SYE, 35" BFG MT KM2's, 4.56 gears, & D44a locked |
#3 |
It seems pretty simple now that i know what i am doing. But damn that PB blaster **** sure can make you sick haha. The fumes really got to me.
#4 |
they're easy!
when i installed mine, honestly i spent just as much time figuring out the strangely worded directions and trying to make out the pictures. once i knew to put the spacers on the top, and once i figured out that half of the directions were just taking about the rear bumpstops THAT DIDNT NEED DIRECTIONS ANYWAY i was done in a few hours and passed out when the beer was gone. dont know about a ZJ, but i didnt need spring compressors with my WJ. my front axle was off at the time because i had to replace literally everything on the front end except for 2 CA bushings. i remember bolting up 1 CA on each side, then jacked up both sides or something to connect the steering etc. for the rear, i took the wheels off and jacked up the OPPOSITE side that i was working on and the spring fell right out. i might have unbolted a CA or two to fit the longer springs and spacers on.
I have a modified 1999 WJ and a stock 2001 WJ Tread Lightly Pictures PARTED OUT 8 WJ Grand Cherokees ! ! ! ! ! ! |
#5 |
The rears go on easier then the front.
The spring compressors arent needed.. (front or back)
- Joe - '95 Jeep Grand Cherokee Laredo I6 4.0L 242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs Moog Cargo Control Springs Magnaflow Converter - Dynomax Muffler 235/75/15 AT Uniroyal Liberator Tires |
#6 | |
2009 Red Rock JK Unlimited Rubi 2006 Scion xA 1999 WJ Limited Quadradrive V8 1997 Chevrolet Z71 1994 ZJ Laredo 4.0 - Sold Thanks for the IR Remote Smokinbk. |
#7 |
Jeep Jedi Master
Kpax had a nasty time with a spring compressor. It cost him a couple of stitches in the forehead.
Hunter
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns and 33 Bridgestone Duelers Detroit and true trac Red Jeep Club Member REDNECK JCM Texas Jeep Owner #6 USN Jeep Club #4 http://www.kevinsoffroad.com/ 602.841.3355 For your performance needs: kolak@kolakperformance.com 480.998.3661 |
#8 | |
#9 | |
#10 | |
are you serious? if you are, i do have better things to do than make up stories. i can post my plastic surgeons bill and a pic of my forehead? let me knoe ![]() funny thing is, i never finished tightening that link until a couple weeks ago when the clunking got worse.
#11 | |
#12 | |
PS. The same applies to Casper about his BB |
#13 | |
im at school 'till 6:30...
#14 |
Jeep Jedi Master
I didn't have the a spring compressor fail.....I had a hilift slide off a slider while I was underneath the jeep. Luckily, it missed my knee by a rrubio and just dented my rear passenger door. BTW, I'd be dead if I had not placed a jackstand under the slider to prevent it from falling.
Hunter
#15 |
i didnt have to use pb blaster or anything like it when i did my BB. my bolts came right out. huh.......
Limited WJ on 31's |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
