BB spacer measurments. - JeepForum.com
post #1 of 9 Old 08-23-2013, 07:29 PM Thread Starter
thudsonjr
Could someone measure their BB spacers? I need diameter, and the size of the hole in the middle. And the amount of cutout for the rear spacer (on the side). I'm trying to have a guy make mill me some out of aluminum
--1995 ZJ- 4.0L, 300000+ miles (i think) 265-75r15 tires, Aero race wheels, no lift
--1996 BMW 328is-intake, exhaust, H&R lowering springs, 17x8 ASA wheels(painted white)
thudsonjr is offline
post #2 of 9 Old 08-23-2013, 08:04 PM
NinetySevenZJay
why do u want aluminum? poly is much better and wont rust, bend/dent, or squeak. plus they're cheap
NinetySevenZJay is offline
post #3 of 9 Old 08-23-2013, 08:05 PM
AnotherRedZj
Jus buy a BB for like $60
AnotherRedZj is offline
post #4 of 9 Old 08-23-2013, 08:16 PM Thread Starter
thudsonjr
Well I figured I'd let my friend get some practice at the same time
post #5 of 9 Old 08-23-2013, 09:00 PM
Cherokee95kid
Metal budget biosts will end up doing damage to the spring perch that's why they are poly because thy absorb the abuse the springs put on the perch.
Cherokee95kid is offline
post #6 of 9 Old 08-24-2013, 11:22 AM
StellaTheZJ
Interesting opinion... tell me, I've been using Aluminium spacers for about 20 years now, on two Jeeps (XJ/ZJ), with over 250,000km combined mileage. At what point should I start looking for this damage?
I cut a piece of inner tube rubber to put between the spacer and the perch, and then reused the stock isolator between the spacer and the spring. No problems I've ever seen.
Here are some specs I found for ya. Mine actually have a taper turned into them to transition between the two IDs, which more closely mimics the shape of the spring perch, but I'm sure these'll work great too:
I got these specs from an INSANE facebook page on incredible XJs. A lot to learn from the pics on there!!!
https://www.facebook.com/pages/Jeep-...32229476843194
StellaTheZJ is offline
post #7 of 9 Old 08-24-2013, 11:27 AM Thread Starter
thudsonjr
So those there are a 70mm lift and the inside taper is from 65mm to 54mm? Why is there the 20 mm area where it is bigger? I've never seen that before
post #8 of 9 Old 08-25-2013, 08:51 AM
bigfoot493
here post #12
http://www.jeepforum.com/forum/f9/ho...anyone-973645/
1994 5.2 jeep grand cherokee laredo
1993 4.0 jeep grand cherokee laredo
bigfoot493 is offline
post #9 of 9 Old 08-25-2013, 01:47 PM
PolkaPower
I just took some Daystar spacers out I can sell you PM if you are interested.
PolkaPower is online now
