BB...need help asap. - JeepForum.com
post #1 of 17 Old 05-01-2005, 05:06 PM Thread Starter
nashmd454
nashmd454's Avatar
I am stuck on the rear spacers. I have the front ones done but when I got to the rear I pulled the rubber piece off and went to slide the spacers on but the rubber piece does not go back on after the spacers are on. Do I leave the spacers on and not put the stock rubber piece on or what. Need help fast.
96' JGC V-8 5.2L ltd.
way too much to list.
Thought for the day:
If GOD gave HIS only son for us...can't we at least give HIM an hour of our time a day.
nashmd454 is offline
post #2 of 17 Old 05-01-2005, 05:11 PM
Derek33
Derek33's Avatar
i think the stock spacer that was already on your jeep should stay in place, and the aftermarket spacer sits between the spring and your stock spacer.
i could be wrong tho.
good luck!
Derek33 is offline
post #3 of 17 Old 05-01-2005, 05:16 PM
matt.x
matt.x's Avatar
if i remember correctly, the stock spacer is not required (but you will lose how ever much boost that it provides). Thus, I would keep it, and use it as previously posted ...
Matt
Red Jeep Club Member #237
matt.x is offline
post #4 of 17 Old 05-01-2005, 05:17 PM
zaq123
zaq123's Avatar
1941 JK Wrangler
Don't install stock spacer in the rear as it will level intself and cus there aren't enough space ( with 2" BB) on spring retainer unless you've got extended ones.
You're better of without them if you do any offroading as it would good to loose your rear spring on a trail. Don't forget to get an alighment after install
zaq123 is offline
post #5 of 17 Old 05-01-2005, 05:19 PM Thread Starter
nashmd454
nashmd454's Avatar
good luck!
We tried that but it wiggeled really bad. Way too loose for secure feeling
post #6 of 17 Old 05-01-2005, 05:20 PM Thread Starter
nashmd454
nashmd454's Avatar
That is what we were thinking...with the rake as is on the zj it would now be level without the stock rear spacer. So the next question is that we were right to install the front stock ones with the new spacers right.
post #7 of 17 Old 05-01-2005, 05:23 PM
zaq123
zaq123's Avatar
1941 JK Wrangler
Did you get 2" BB?
If yes I WOULD NOT put stock spacers in the rear on. I know some people who end up
removing them after install so when I did mine I left them out.
zaq123 is offline
post #8 of 17 Old 05-01-2005, 05:26 PM
zaq123
zaq123's Avatar
1941 JK Wrangler
Yes, it's perfectly fine. As you probably noticed you 2"BB is not really 2"
Using stock ones upfront should give you 2" all the way around.
Did you get new shocks?
zaq123 is offline
post #9 of 17 Old 05-01-2005, 05:26 PM
10achik
I ate what?
10achik's Avatar
That thing is called an isolator and the spring fits into the isolator, I took the isolator out and then put the BB where the isolator was, granted I had to dremel out the bottom of the BB so it will fit around the retainer at the bottom (then used a rubber mallet to get it on the retainer good and snug) then if you notice the BB is cupped out and the isolator fits in that perfectly or at leat the Daystar BB was. So basicly going from the bottom is should be coil spring retainer, BB Spacer, rubber isolator, coil spring, then top spring retainer.
Ken
99 GC Limited - 4.7L HO V8, 6.5" IRO HC LA lift, F&R D44s locked & trussed, 242HD, IRO TC Skid, KMA Bumper, 35's
2006 Saturn Redline -2.0L Eaton supercharged I4, GMPP Stage 2, Custom Tune, AEM CAI, Ebiach Pro Kit w/ swaybars, EVO Ventus V12s (13.76 @ 103.85)
2006 Pontiac G6 GTP
2012 Nissan Juke - (hers)
2000 SV650 - naked, integrated tail light, sliders, corbin, pilot roads, RK chain & sprokets, D&D full exhaust, FactoryPro Stage I jet kit, +4 Ignition Advancer, Barnett race clutch
2006 Triumph America 900 - Full Dresser
January 2009 Grand Cherokee of the Month (GCOTM)
10achik is offline
post #10 of 17 Old 05-01-2005, 05:26 PM Thread Starter
nashmd454
nashmd454's Avatar
Did you get 2" BB?
If yes I would put stock spacers in the rear on. I know some people who end up
what........then if you put the stock in then what did you do with the bb spacers. Doesn't that make for a weird ride with the front so high and the rear normal. I am just going to go with the bb and leave the 2"bb daystar spacers in and leave the stock rubber isolators off.
post #11 of 17 Old 05-01-2005, 05:28 PM
zaq123
zaq123's Avatar
1941 JK Wrangler
MISPRINT
I meant I WOULD NOT. Sorry man
zaq123 is offline
post #12 of 17 Old 05-01-2005, 05:32 PM Thread Starter
nashmd454
nashmd454's Avatar
I quit...it seems as if I am getting more confused here. There is no way to fit the isolator over the bb spacer. We tried to pry the isolator over the spacer but it was a no go. And some here say go without the stock and it will just leave my ride leveled all the way around instead of the fwd rake. I will just leave the isolators off and install the bb spacers. If I confused anyone then please forgive me. I am just more lost now trying to figure out what you guys were trying to explain to me.
post #13 of 17 Old 05-01-2005, 05:34 PM Thread Starter
nashmd454
nashmd454's Avatar
MISPRINT
ok...that sounds better. That is exactly what I was planning on doing (leaving the stock spacer off and just have the bb spacer on). I have the Daystar 2"bb too. I am also installing my cross drilled/slotted rotors too. I took plenty of pics.
post #14 of 17 Old 05-01-2005, 05:41 PM
zaq123
zaq123's Avatar
1941 JK Wrangler
Here is what I did
FRONT: install BB than stock spacer than coil spring
REAR: install BB than coil spring
Note : stock spacers were left out in the rear as there is no room for them.
Follow your instincts []IIIII[]
zaq123 is offline
post #15 of 17 Old 05-01-2005, 07:05 PM Thread Starter
nashmd454
nashmd454's Avatar
Got it done...thank you guys for responding so quickly. It looks good....just one problem...one of the sway bar end links nots will not tighten up. The entire bolt(the part that has threads)and nut spin when you try to tighten. So I assume it is broken. I will go get a new set of end links and replace both sides. I might go with a new track bar (loose) and alignment all at once. I have been told the tack bar is bad but the ride felt fine; but what will it hurt to have new one anyways. Thanks again. Oh and the new brakes are WOW....what a difference in stopping.
Need Help Asap drob951 ZJ Grand Cherokee Forum 5 08-14-2009 02:11 AM
HELP!!!! please i need help asap!! ECMUDSLINGER ZJ Grand Cherokee Forum 13 05-25-2009 03:17 PM
Need Help Asap!!!! sparelink ZJ Grand Cherokee Forum 8 01-10-2009 07:23 PM
Need Help Asap Please J33Pyj ZJ Grand Cherokee Forum 4 05-19-2008 05:15 PM
Need Help ASAP helpmeplz101 ZJ Grand Cherokee Forum 4 04-11-2005 01:02 AM
