Battery wont go more than 12a? - Page 2 - JeepForum.com
post #16 of 22 Old 04-28-2012, 08:50 AM
gunner44
Don't get involved in major grounds at this point unless major items are being involved. Considerate on listing what is acting out of the ordinary, and what you and the jeep are doing when something happens. My wife calls it being methodical. Remember what is running correctly is as important as what is not, for knowing that prevents you from going off in the wrong direction. The last thing you do is draw a conclusion. Drawing a conclusion only happens after you have sufficient information to do so. The other thing, do not try to solve two problems, that have very little to do with one another at once. It is easy when you are paying hypered attention to find all kinds of things that separate your jeep from a new one.
After you make your list, and only after, go to proving if the draw that is indicated is real or a gauge or circuit problem. The alternator needs to be checked. Cushion, what is coming out of that alternator can get you, if you are at all uncomfortable have it done by someone. If the alternator is operating correctly, then the battery. Quick check, With the engine running turn on everything, radio, headlights, ac to high, hit the breaks, turn wheels - are the headlights dimming? Trust me, if the alternator is not working they are.
gunner44 is offline
post #17 of 22 Old 04-28-2012, 12:51 PM
Uniblurb
Uniblurb's Avatar
Agree on being methodical in troubleshooting but the grounds are one of the most important parts of the electrical system and should not be ignored for now. The PCM, alternator, sensors, etc, are all grounded to the engine and the grounds should be clean/making good contact.
On one of the small field terminals on the back of the alternator is a tan/blk, or dark green wire, which leads directly to the PCM. This provides feedback between the alternator and PCM while the PCM functions as a switch for turning the alternator field on/off for putting out the correct voltage. Kind of a vicious circle where the PCM and alternator better be grounded properly on the main engine grounds or the alternator will not put out the correct voltage. Also a good reason for making sure the all contacts on the back of the alternator are good/clean.
It should also be noted whenever you buy a new alternator now they often have a warning you better have a good ground strap going to it or the alternator won't work right and will be damaged.
I recently removed my alternator and it tested fine. But I also removed the bracket from the engine and couldn't believe the varnish on the back of the bracket where it contacts the engine. Aluminum and steel don't like each other and cleaned all this off. While maybe not necessary I also ran an additional ground strap from the right/lower alternator ground bolt to the front ground stud under the coil just to be on the safe side. Also used dielectric grease on all contacts.
Uniblurb is offline
post #18 of 22 Old 04-28-2012, 05:03 PM
gunner44
I totally agree, and your wright up holds very useful information. I just cut and pasted it in by data bank. Until I see a list though, which is what I need, I can go no further.
gunner44 is offline
post #19 of 22 Old 04-29-2012, 08:23 PM Thread Starter
Camswe
Well today i checked and cleaned all of the grounds and battery connections except the firewall/gauges ground, i couldn't find that...but after about 2h and a lot of grease i finished and i started up the jeep 4 times in a row and my volts read 14, perfectly in the middle. Maybe i fixed it, maybe not i only had time to start her up a couple times because i had to go recover my old xj project. hopefully will get to go drive it for a while tuesday
Camswe is offline
post #20 of 22 Old 04-29-2012, 09:05 PM
phitmein
phitmein's Avatar
sound like a winner, good job Sir.
I have seen more Jeeps fixed by cleaning the various connections than anything else.
Phit
Edit: how about the radio is it working now too ?
phitmein is offline
post #21 of 22 Old 04-30-2012, 01:06 AM
Uniblurb
Uniblurb's Avatar
Good deal Camswe and glad you're back to full voltage. Cleaning all those grounds will also more than pay for itself in the long run.
Uniblurb is offline
post #22 of 22 Old 04-30-2012, 02:01 AM
5-90
5-90's Avatar
1988 XJ Cherokee
The ZJ doesn't have a firewall ground between the engine and chassis - everything else is just ducky.
Probably 85-90% of the electrical problems I've tracked down on vehicles in the last 30-odd years have been due to a shonky ground somewhere - clean up the lug (or just replace it outright,) replace the screw with a clean one, and clean up the contact patch, and everything's fine.
I just have a bit of a blind spot sometimes - since it's the first place I look, I usually figure it's the first place everyone else looks as well.
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline
battery , electrical issue
Help! alarm wont turn off - killing the battery! mattc123 ZJ Grand Cherokee Forum 13 11-18-2013 03:12 PM
Jeep died, no power to hvac and wont crank starter. Brand new battery, any ideas?? jpclinging ZJ Grand Cherokee Forum 3 04-05-2010 04:15 PM
Battery wont hold a charge. takethisride ZJ Grand Cherokee Forum 2 03-08-2010 11:10 AM
Need Help Fast Connected Battery And Now My Jeep Wont Start Orpen ZJ Grand Cherokee Forum 43 09-08-2009 06:40 PM
Battery wont hold a charge? ddoffroad ZJ Grand Cherokee Forum 1 05-26-2009 09:27 AM
