Battery Wont charge - JeepForum.com
post #1 of 7 Old 01-15-2014, 11:17 AM Thread Starter
tmredmond
Battery Wont charge
My ZJ has a new battery, new alternator, and clean terminals and will not charge. If I charge it up it will turn on, but about a min later the battery gauge drops to zero.
My next guess is to replace the alternator plugs.
Also, the battery is oversized, but I was told that shouldn't be an issue, could that cause this?
tmredmond is offline
post #2 of 7 Old 01-15-2014, 11:27 AM
jorhay
It might be the voltage regulator, not the battery. Have you had the new pieces checked to see if they hold a charge or output a charge?
jorhay is offline
post #3 of 7 Old 01-15-2014, 11:43 AM
txbass06
Isn't the voltage regulator built into the PCM?
txbass06 is offline
post #4 of 7 Old 01-15-2014, 11:48 AM
jm8881
That's odd. If the battery is fully charged then the jeep should run for more than a few minutes.
jm8881 is offline
post #5 of 7 Old 01-15-2014, 11:49 AM
jm8881
Yes it is.
jm8881 is offline
post #6 of 7 Old 01-15-2014, 11:53 AM Thread Starter
tmredmond
It will run, it just reads the battery at zero.
post #7 of 7 Old 01-15-2014, 11:54 AM Thread Starter
tmredmond
I have not.
alternator issue , battery , grand cherokee , wiring alternator plug
