battery temp sensor error - JeepForum.com
post #1 of 8 Old 08-06-2008, 11:52 PM Thread Starter
sadass
I have 98zj 5.9 , the check engine light came on, took jeep to advanced auto to have code read, and I was told trouble code was for a battery temp sensor fault. any have any info on trouble shooting this circuit. anyone have the same problem.
sadass is offline
post #2 of 8 Old 08-07-2008, 01:19 AM
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
i have never heard of a temp sensor on the battery....
im prety sure i dont have one, but i dont know now... you got me thinking...
hard working private first class in the United States Marine Corps.
Originally Posted by shift_grind View Post
It's threads like this that make me wonder why people lift there jeeps
its comments like this that make me wonder why some people are jerks.
build thread:
5.9 ANDY is offline
post #3 of 8 Old 08-07-2008, 01:28 AM
elmer_fud
I think it is in the battery box. It would sit under the battery, and tell the computer when it is fully charged. I have heard of it before, so i think it exists Andy, or at least on the older GC
Edit: or maybe it is on all ZJ, since you both have 98's
Brian
95 ZJ, 5.2 V8,160,000 miles
Originally Posted by Speedycat View Post
I am not one to be changing lanes at 70 mph on a lifted truck on 33's, but since I am in Miami, I have to be prepared for the continuous influx of new drivers whose previous ride was a bicycle with wooden wheels.
Originally Posted by FPKites View Post
badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, Mushroom!!! :D
Originally Posted by ZeeJay1997 View Post
Or just tie a 12 lb fish to a one foot pipe.
elmer_fud is offline
post #4 of 8 Old 08-07-2008, 01:47 AM
keith20mm
It's under the battery, and under the battery tray, sticking its little head up through the bottom of the tray. To get at it, remove battery, then unbolt whatever is in the way of the tray, and then unbolt the tray, and tilting it to one side, you'll see the connector under, pointing upward. Unlock the latch, then depress thumb latch, disconnect connector. Probably spray WD 40 into the latch, since no one ever goes here, it's filled with dust, and will be difficult to unlatch. So, Kroil, WD40, etc, to loosen it up before messing with the latches. It's a temperature sensor... and there isn't much to go wrong with it, except a bunch of acid, or bad connection. The sensor itself snaps out vertically from the battery tray. It's an actual sensor (a pot), and not just a switch.
keith20mm is offline
post #5 of 8 Old 08-07-2008, 01:54 AM Thread Starter
sadass
any Idea what the purpose of that temp sensor would be? why does the jeep need to know battery temp?
sadass is offline
post #6 of 8 Old 08-07-2008, 03:47 AM
theksmith
2003 WJ
i believe it's so that it can adjust the rate of charge based on temperature
UPDATE: the FSM confirms that: "...temperature data, along with data from the monitored line voltage, is used by the PCM to vary the battery charging rate." in my WJ FSM it also says that it affects the OBD systems: "Most OBD II sensors are disabled below 20 degrees." interesting!
theksmith is offline
post #7 of 8 Old 08-07-2008, 07:52 AM
ajmorell
ajmorell's Avatar
Yep that's exactly what it is for.
ajmorell is offline
post #8 of 8 Old 07-11-2010, 02:49 PM Thread Starter
sadass
Last time was almost 2 years ago when I threw this code for Battery temp sensor error. At that time I put a new battery in because it needed it and the fault went away. Today the cel is back for Battery sensor. funny, last couple of week started to notice my battery is not holding a charge like it should, leave the tunes on in the car for any length of time and the Jeep will need a jump. I have never hear of this on JF so I thought I would follow up on this old Thread of mine for future fault related searches. Seems like my cel for battery temp sensor faulty is acting as a early battery failure warning.
5NineZJ,35mtr/k IRO 7" LA F/R Detroit F/HP-4.56 R/Aussie 44A. ARB Snorkel/JRC Sliders/ Protofab w/9500S./Bushwhackers. Novak242 TCcable.
sadass is offline
Error P1294, dead battery after vacation ABerry ZJ Grand Cherokee Forum 10 09-15-2009 08:41 PM
What does a battery temp sensor actually do? MeWJWifeZJ ZJ Grand Cherokee Forum 1 11-12-2008 11:04 AM
Jeep Error Code P1492 - Ambient/Battery Temp Sensor headpro2 ZJ Grand Cherokee Forum 9 12-29-2007 11:07 PM
solar sensor and in vehicle temp sensor Bekim ZJ Grand Cherokee Forum 10 10-08-2007 10:04 AM
Output Speed Sensor error ricksuchecki ZJ Grand Cherokee Forum 7 09-04-2007 07:35 PM
