Battery going dead overnight - JeepForum.com
post #1 of 37 Old 01-31-2011, 06:41 PM Thread Starter
BackBrakeBilly
Here's the scoop...
1998 GC 4.0, the battery is dying overnight or at the most every other day unless the Jeep is driven. Traced the short down to the Instrument Cluster circuit by removing the fuses as I checked the draw on the battery. My question is how many things are operated off of the Cluster Circuit?
The headlight switch is working fine and doesn't change the voltage draw when its disconnected...
Need help please!!!
BackBrakeBilly is offline
post #2 of 37 Old 01-31-2011, 06:46 PM
CRAWLING 98
Wheeler
CRAWLING 98's Avatar
Originally Posted by BackBrakeBilly View Post
Here's the scoop...
Need help please!!!
How old is the battery. It could be going south due to age. does the battery die if you disconnect the terminal for a couple days.
Group W Bench
CRAWLING 98 is offline
post #3 of 37 Old 01-31-2011, 07:13 PM Thread Starter
BackBrakeBilly
The current battery is on;y a few months old. The battery will hold a charge if its disconnected so I pretty sure its not the battery.
I traced all the circuits that run through the fuse panel with a DVM and the only one that made a differenc in the drain was the circuit going to the dash cluster....
Thanks for the imput!
post #4 of 37 Old 02-01-2011, 08:50 AM
SGTCornewell
2002 KJ Liberty
i would unhook the battery at night and at work for a few days just to be sure its ok. batteries are man made, they fail. im not sure if the cluster works off the ignition switch, bcm, or a relay. any of them COULD be the problem. all else fails, drink some water and check your grounds.
SGTCornewell is offline
post #5 of 37 Old 02-01-2011, 11:55 AM Thread Starter
BackBrakeBilly
Took the battery loose overnight and checked it with my meter and it seems to be holding a charge when its unhooked from the Jeep.
The circuit in question runs all the dash lights and all the gauges, can someone tell me what else is on that circuit?
post #6 of 37 Old 02-01-2011, 03:48 PM
SGTCornewell
2002 KJ Liberty
ill try to look in my book tonight. im on standby for the ice storms here in indy so i might not get to it.
post #7 of 37 Old 02-01-2011, 03:59 PM
JS97ZJ
Which fuse in which panel did you pull in order for you to stop the drain.
Some of the fuses in the PDC (under the hood) power the JB (in the passenger kick panel) that supplies the power to the instrument panel.
It also ties in with the BCM which operates all of your interior functions, like the alarm system, interior lighting and so on. Did you check the rear hatch light switch was turned off? Overhead courtesy lights? My daughter left those on for me one evening....
JS97ZJ is offline
post #8 of 37 Old 02-05-2011, 06:03 PM Thread Starter
BackBrakeBilly
Ok I pulled the #7 (Cluster) fuse out of the fuse block at the kickpanel, 3 days and the Jeep starts right up which means the battery is not the problem but rather something in that circuit...
I know this circuit feeds the Instr. cluster lights and gauges but what else does it feed?
I drove it when I cranked it up and everything else seems to be working.
post #9 of 37 Old 02-05-2011, 10:31 PM
z32gizzle
I just had the same problem. Came out to my Zj and it was completly dead not even starter clicks. Checked fuses and Cluster fuse was blown.... Dunno why it was blown but I replaced it and so far so good.
z32gizzle is offline
post #10 of 37 Old 02-05-2011, 11:10 PM
JS97ZJ
Fuse #7 powers up the obii scan reader through pin #16 in the data link connector (thats a shot in the dark) check for bent pins there.
Also supplies power for the power amplifier
instrument cluster
BCM (body control module)
and the automatic headlight sensor (on top of the dashboard) that also is connected to the BCM
JS97ZJ is offline
post #11 of 37 Old 02-05-2011, 11:25 PM
smokeyeager
smokeyeager's Avatar
Here's the scoop...
Need help please!!!
Go to http://www.autozone.com/autozone/ click repair info and register for free account, then click vehicle repair guides, chassis electrical, then wiring diagrams. Should take you to a bunch of the diagrams. Going to try to link it but not sure it'll work. http://www.autozone.com/autozone/rep...00c152800a9cf4
Edit: Forgot to say to add your vehicle YMM info topull the right diagrams.
smokeyeager is offline
post #12 of 37 Old 02-07-2011, 10:11 PM Thread Starter
BackBrakeBilly
Another update...
I unplugged the white connector that goes to the BCM and the battery drain went down to normal for the Ignition off status.
Plugged the white connector back in and started checking the switches down line from the BCM with nothing having any effect so far...
Does this sound like its the BCM that has the short?
I did notice a very slight flickering of the dash lights when driving it tonight.
I unplugged the headlight/dimmer switch and it didn't have any effect on the power drain, could a short in the BCM be causing the dash lights to have the slight flicker?
Thanks for all the help so far and for the help to come!
post #13 of 37 Old 02-08-2011, 01:37 AM
JS97ZJ
The #7 fuse goes into the BCM through that white connector.
Other circuits that are connected through that connector are...
headlight auto sensor
radio control (steering wheel)
wiper park switch sense
courtesy lamp relay control
a/c select sense
headlamp relay control
horn relay control
rear defogger relay control
fused ignition switch output (run/acc)
panel lamp driver
washer pump sense
windshield wiper switch signal
panel lamp dimmer
park lamp relay control
fog lamp relay control
intermittent wiper relay control
There is an entire manual dedicated to troubleshooting the BCM and everything connected to it. You could try and pull some of the associated connectors or relays to further track down ur problem, but I get the feeling that it's the module itself.
If you need more info.......
JS97ZJ is offline
post #14 of 37 Old 02-08-2011, 03:36 AM
phitmein
phitmein's Avatar
Uh-umm ... If it is hurting your head to badly here, and if you have it pinned down to the white connector, then just interupt it with a on/off switch and then use it when you cut your ride off ...
Or hard wire it in ...
Problem solved ???
Or chase that b*tch ...
Phit
phitmein is offline
post #15 of 37 Old 02-08-2011, 05:09 PM Thread Starter
BackBrakeBilly
OK,
I went and picked up a good working BCM, installed it and the short is still there!
I am open for suggestions...
Could someone point me in the direction of a good wiring diagram for the wires that go to the white connector? I guess the next step is to start tracing those wires down....
Thanks!
2005 Jeep Grand Cherokee Limited Dead Battery overnight davepull WK Grand Cherokee & XK Commander Forum 9 01-12-2014 09:11 AM
Battery has gone dead? Again? ZJ_Dave ZJ Grand Cherokee Forum 3 02-06-2010 02:17 PM
Battery goes dead overnight petersyj95 ZJ Grand Cherokee Forum 5 01-26-2010 12:49 PM
Can I install my own Battery? What to do after my battery is dead coolest_Stan ZJ Grand Cherokee Forum 36 09-20-2009 11:16 AM
Question about battery voltage after overnight storage sniperdude ZJ Grand Cherokee Forum 6 02-09-2009 12:00 PM
