battery drains with no reason - JeepForum.com
post #1 of 10 Old 07-19-2011, 05:18 PM Thread Starter
chrishill4000
I have a 1995 jeep grand cherokee limited. When you let the jeep sit overnight and you try to start the jeep it tries to start then quits and a loud clicking noises comes from the jeep somewhere (cant tell where the click is too loud to tell in the engine bay). after it starts the loud clicking the alarm goes off. if you cut the alarm off and hook jumper cables to the jeep it starts fine. Tested both alternator and the battery and both tested good. no lights are being left on at all not even the light under the hood or anything. Please help.
chrishill4000 is offline
post #2 of 10 Old 07-19-2011, 05:20 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
time to get out the multimeter and see where the drain is.
ratmonkey is offline
post #3 of 10 Old 07-19-2011, 10:07 PM
phitmein
phitmein's Avatar
Did you load test the battery ???
I have seen part stores be wrong about alternators and/or batteries being good ...
it could just be the battery ...
a simple test is, after driving it (to charge the batt.), park it and disconnect the neg. batt. terminal over night,or even better, 24 hours and see what it does after reconnecting it ...
phitmein is online now
post #4 of 10 Old 07-20-2011, 12:47 AM
BlueDevil
^that.
Your batt could be old and unable to keep the charge well. Happened to me, only my lasted 2 days. 3rd day I had to turn her on, otherwise she wouldn't crank without jumper cables. Replaced batt and all is well. The simplest test is what phitmein said, fully charge batt, disconnect (-) cable overnight or better two, and then see if it cranks. If not, the batt is goodbye. If it does, then ratmonkey's way - multimeter out & see who's missing the bedtime...
Beauty is in the eye of the beer holder
* 1994 ZJ (by VIN) with a 1995 engine (PO knows why)
BlueDevil is offline
post #5 of 10 Old 07-20-2011, 12:58 AM
Delta347
I had the same issue, I had to ground out my alarm system in my 1995 to stop te drain.
My alarm would go off randomly in the middle of the night for no reason at all.
Even when it didn't it would drain over night for no reason.
It went through 2 brand new batteries in 1 month and an alternator so that's when I said F-it and grounded the alarm. Only thing that seemed plausible.
My iPhone will poison your Android.
Originally Posted by Leans93 View Post
So ghost has a plug in his hole and opihi has a gaping hole, Do I need to worry about this hole at all? I just don't want to start her up and have something spewing out of it.
Side Effects may include dry mouth, nausea, vomitting, water retention, painful recolage, hallucination, dementia, psycosis, coma, death, and halitosus. YJs are not for everyone please consult your physician before use.
Delta347 is offline
post #6 of 10 Old 07-21-2011, 04:55 PM
Kevin86me
i had a problem like this turned out to be the voltage regulator pcm
Kevin86me is offline
post #7 of 10 Old 07-25-2011, 06:02 AM
larry408
If you still have the hood light connected try dis-connecting it. That was what was pulling my battery down. It was staying on all the time.
USAF 1968-1972
NRA Life
1991 YJ
1973 Dodge Dart Sport
1980 Honda CB900c
larry408 is offline
post #8 of 10 Old 07-25-2011, 06:04 AM
BlueDevil
Yup, that b'stard has mercury switch in it, can't see it, and if it goes south, light might either be on 24/7 or never come on.
post #9 of 10 Old 07-25-2011, 06:53 AM
MAUSS
Section 8A of the Factory Service Manual describes the troubleshooting technique for finding a high-current, ignition off draw. The typical draw should only be 25 mA.
'93 Limited (sold), '96 Laredo
MAUSS is offline
post #10 of 10 Old 07-25-2011, 09:31 AM
stageninja
That Rigger Guy
stageninja's Avatar
I know you say no lights are being left on but a sticky switch on the brake light @ the pedal was the draw on my wife's '98 zj.
Mine '97 White, ZJ Ltd, 5.2, Up-Country Suspension, Kolak ignition, Kolak/Magnaflow Exhaust
Her's '98 Chargold ZJ Ltd. 4.0 2wd
Our 1st '97 White, ZJ Ltd, 5.2, The parts Jeep for 5 years...R.I.P. Sent to Pic-A-Part 5/17/2013
stageninja is offline
1998 Grand Cherokee ZJ Battery drains in a day or two quarkdude ZJ Grand Cherokee Forum 20 07-10-2014 02:30 AM
Battery drains Fr3sh94 ZJ Grand Cherokee Forum 1 06-26-2011 07:09 PM
Battery keeps dying for no reason... mikeprekopa ZJ Grand Cherokee Forum 4 07-22-2009 03:06 PM
Electrical.....Battery Drains lmdream ZJ Grand Cherokee Forum 2 04-07-2004 05:42 PM
grand cherokee battery drains alpine ZJ Grand Cherokee Forum 2 05-27-2003 07:39 PM
