Battery draining issue - JeepForum.com
post #1 of 10 Old 01-27-2013, 09:46 AM Thread Starter
ThatONeJeePeR
1991 XJ Cherokee
I'm having an issue with my battery constantly draining when i try to start it.
The volt meter reads about 12 when I first attempt to start it. As soon as i turn the key and the engine starts cranking the batery immediatly drains.
Anyone else have this problem? I had the battery and alternator checked and there still good. Any help on this situation would be greatly appreciated!
ThatONeJeePeR is offline
post #2 of 10 Old 01-27-2013, 11:04 AM
a70eliminator
Definately sounds like a dead cell in the battery, but if your 100% confident in the battery load test then my next move be to load test the starter, could be the starter windings have a resistance breakdown, I've had this happen before on a ford starter had a breakdown in the winding insulation, it would do just as you describe but only when hot, once cooled it was good. If I shut down while hot I always knew I would be staying awhile LOl.
a70eliminator is offline
post #3 of 10 Old 01-27-2013, 11:31 AM
xcaliber81
I think when my starter was failing it was drawing lots of power it would kill the battery, in fact it made my + battery clamp go much darker than - and i replaced them at the same time.
xcaliber81 is offline
post #4 of 10 Old 01-28-2013, 09:39 AM
BigClay
I would try a brand new battery and see if that fixes it.
Current: 98 TJ, 33" TSLs
Past: 94 ZJ, built for the rocks
BigClay is offline
post #5 of 10 Old 01-28-2013, 06:16 PM Thread Starter
ThatONeJeePeR
1991 XJ Cherokee
I had my battery and alternator checked at oriely's and they tested good
post #6 of 10 Old 01-28-2013, 06:33 PM
carrasaurus
I'm experiencing something kinda similar...
http://www.jeepforum.com/forum/f13/p...ttery-1470488/
One piece I left out of my thread was that the last battery I returned indeed had a bad cell. What would cause a battery to lose a cell?
carrasaurus is offline
post #7 of 10 Old 01-29-2013, 11:29 AM Thread Starter
ThatONeJeePeR
1991 XJ Cherokee
Over charged? Charged to to long at a higher voltage than permitted
post #8 of 10 Old 01-29-2013, 11:31 AM
mrchips59
Charge up the battery fully, then load test your battery disconnected from rig Should tell you if it is good or bad.
mrchips59 is offline
post #9 of 10 Old 02-03-2013, 12:20 AM Thread Starter
ThatONeJeePeR
1991 XJ Cherokee
turns out it was the battery!!! did a load test on it and it dropped to 6 volts!! dang orielly's! dont trust 'em
post #10 of 10 Old 02-03-2013, 12:05 PM
Spanovich008
Glad that you found the problem!
don't be afraid to put the "fun" in "dis-functional"
Spanovich008 is offline
