battery disconnect - Page 2 - JeepForum.com
post #16 of 24 Old 03-23-2013, 06:18 AM Thread Starter
coralman
USER OF PARTS CATALOGS
coralman's Avatar
Leaning towards something like this. Link is just to one half the connector. That way if the cable clamp went bad I could just make up another and to disconnect I just unplug.
http://www.grainger.com/Grainger/AND...&cm_vc=IDPRRZ1
Originally Posted by HighLonesome
coralman is offline
post #17 of 24 Old 03-23-2013, 06:28 AM
TheRealOldjeep
I'd want to know what the inrush rating is on that thing. I know that they use something similar for hooking up jumper cables on tow trucks, but 175 amp doesn't seem like enough unless it has a much higher inrush rating.
Chuck P
94 YJ 2.5L/AW4 (Gone)
98 ZJ Limited 5.2 - sons car
97 TJ 2.5L/30RH - daughters car
My site
TheRealOldjeep is offline
post #18 of 24 Old 03-23-2013, 06:35 AM
ZeeJay1997
I would think it needs to be rated higher than than the main fuse on the PDC. (175)
ZeeJay1997 is offline
post #19 of 24 Old 03-23-2013, 07:50 AM
TheRealOldjeep
Starters don't run through fuses
Chuck P
My site
post #20 of 24 Old 03-23-2013, 08:26 AM
MaintMech
Old and in the way
MaintMech's Avatar
That will work quite well, I'm thinking.
I've seen these used on forklift batteries and they fail more from physical abuse than from electrical overload. As a matter of fact the only time I've seen the connections fail is due to operator error.
It'll handle anything your Jeep will put out.
'96 Grand Laredo, 4.0, Stock, Daily Driver
I fought Oracle and Oracle won!
If the faith isn't there,the doubt is.
MaintMech is offline
post #21 of 24 Old 03-23-2013, 08:39 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
yep, those are commonly used on electric jitneys. i've seen a few melted. the motors on those particular trucks had shorted internally and caught fire before that though.
ratmonkey is offline
post #22 of 24 Old 03-23-2013, 08:49 AM Thread Starter
coralman
coralman's Avatar
This was a medium rated one, they got them rated up to 350 I think. A good crimp with a hammer crimper or hexagon crimper, fill the voids with solder, heatshrink the cable entries and exits and it should be good to go.
coralman is offline
post #23 of 24 Old 03-23-2013, 08:54 AM
TheRealOldjeep
These are more along the lines of being properly rated for connection to a starting battery:
http://www.centurytool.net/Plug_In_C...ts_s/16302.htm
The light duty ones are 400Amp, the HD ones are 800
Chuck P
My site
post #24 of 24 Old 03-23-2013, 10:39 AM Thread Starter
coralman
coralman's Avatar
Thanks for the links OldJeep!
coralman is offline
