Battery Dead - JeepForum.com
post #1 of 14 Old 04-06-2007, 08:56 AM Thread Starter
TriKolor
TriKolor's Avatar
Battery Dead
I have a 5 year old Die Hard in my ZJ. Yesterday up on the mountain it started dying.
This morning in the garage it is dead.
When last started, the engine kept wanting to die if I let the rpms go down to idle.
The voltmeter reading was at 14 volts. Is it the battery, the Alternator. or...?
The numbers on the Alternator are as follows:
5602 7912
121000-3530 12V
DENSO 70113
There is a circle with the number 62 inside in ink/paint on the case.
I don't know the amperage rating, so I don't actually know if the Alternator is enough for what I am asking from it.
I run 2 Amplifiers and trailer lights. and I run all my lights when driving on the street.
Thanks,
TK
Tri-Kolor
96 ZJ Laredo 5.2l V8
3" Skyjacker Lift 31X10.50R15 Pro Comp M/T's
Pro Comp Black Steel series 95 Wheels
Alpine Head UnitAlpine CD Changer Infinity Reference Door Speakers
JL Audio 10" Stealthbox Kenwood Mono Amp
Don't be such a Thule!
TriKolor is offline
post #2 of 14 Old 04-06-2007, 10:31 AM
zaq123
zaq123's Avatar
1941 JK Wrangler
Batteries are not designed to last that long.
zaq123 is offline
post #3 of 14 Old 04-06-2007, 10:54 AM Thread Starter
TriKolor
TriKolor's Avatar
Thanks for the reply.
Battery has only 10 Volts across the terminals. I realize that it is dead but I was wondering if there was/is a problem with my charging system.
I don't want to kill another battery.
Thanks,
TK
Tri-Kolor
TriKolor is offline
post #4 of 14 Old 04-06-2007, 11:35 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
like stated, wet batteries aren't meant to last that long.
ratmonkey is offline
post #5 of 14 Old 04-06-2007, 12:01 PM
LeroyJMC
1994 ZJ
Alt sounds good. Go grab yourself a new battery and you'll be good to go.
2009 Red Rock JK Unlimited Rubi
2006 Scion xA
1999 WJ Limited Quadradrive V8
1997 Chevrolet Z71
1994 ZJ Laredo 4.0 - Sold
Thanks for the IR Remote Smokinbk.
LeroyJMC is online now
post #6 of 14 Old 04-06-2007, 12:44 PM
TravisL1213
i have the original battery in mine
Limited WJ on 31's
TravisL1213 is offline
post #7 of 14 Old 04-06-2007, 12:54 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
the original was in mine when i bought it, i replaced it immediately with a yellow top.
post #8 of 14 Old 04-06-2007, 01:12 PM
zaq123
zaq123's Avatar
1941 JK Wrangler
are you an original owner? There is no way to tell if previous oner's been replacing it at the dealer
zaq123 is offline
post #9 of 14 Old 04-06-2007, 04:41 PM
greasefingers
greasefingers's Avatar
1994 ZJ
There is a code on all batteries that tells you when they where made. It is usually located in one of the corners (on the top but also the sides). Only the first two characters are important. 9A would indicate a battery built in 1999 January. 9M = 1999 December.
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #10 of 14 Old 04-08-2007, 08:49 AM
PA 5.9
If you get a new battery, take the old one back to Sears and get a new one there.
I recently traded in my one month shy of five year old Die Hard Gold battery and they gave me $39.66 for it. That's over half of the original purchase price ($75) and about 40% of the cost of a new one ($95). I practically ran out of the store with the new battery just in case they made a mistake. So those 100 month guarntees are good for something after all!
PA 5.9 is offline
post #11 of 14 Old 04-08-2007, 09:00 AM
greasefingers
1994 ZJ
If one has a five year old battery in there vehicle then it needs to be replaced; even if it is not the cause of a current problem.
I call it preventative maintenance.
Cheers Steve
post #12 of 14 Old 04-08-2007, 12:52 PM
Double E
Double E's Avatar
Agreed, if Travis is really on the orig battery, he's also on borrowed time.
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
post #13 of 14 Old 04-08-2007, 12:58 PM Thread Starter
TriKolor
TriKolor's Avatar
Well, I was wrong, I bought the battery 8 years ago...guess it was overdue....guess I'm not going to complain about the lifespan...Thanks for all the replies...
Tri-Kolor
TriKolor is offline
post #14 of 14 Old 04-08-2007, 06:20 PM
LeroyJMC
1994 ZJ
Glad to hear you got 'er done Tri_Kokor.
2006 Scion xA
1997 Chevrolet Z71
Battery has gone dead? Again? ZJ_Dave ZJ Grand Cherokee Forum 3 02-06-2010 01:17 PM
Can I install my own Battery? What to do after my battery is dead coolest_Stan ZJ Grand Cherokee Forum 36 09-20-2009 10:16 AM
dead battery??? 97 ZJ Steve ZJ Grand Cherokee Forum 13 08-07-2007 02:38 PM
Battery dead STUCKINMUD WK Grand Cherokee & XK Commander Forum 5 07-16-2007 09:36 AM
dead battery over and over fireboy ZJ Grand Cherokee Forum 3 10-01-2005 06:05 AM
