battery or alternator - Page 2 - JeepForum.com
post #16 of 40 Old 07-02-2013, 08:17 PM
dnuccio
Originally Posted by Mickey_D View Post
This.
The expected life of a car battery is 3 to 5 years. If you got 6 years out of a Walmart Special, you did good man.
they say if you get 2 years out of it here in the AZ heat, you're money ahead.
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #17 of 40 Old 07-02-2013, 10:03 PM Thread Starter
cryptic3
My battery died the past week when its been in the hundreds here in Texas
cryptic3 is offline
post #18 of 40 Old 07-29-2013, 12:12 PM Thread Starter
cryptic3
Ok so I bought another battery...... now dont ***** me out but I bought a rebuilt battery 25 dollars, and after 3 weeks the battery once again start but sounds like it has low charge... and just today this morning the battery is, dead.... is it because of the battery I bought or maybe there is a leak somewhere. Any ideas where I can start
cryptic3 is offline
post #19 of 40 Old 07-29-2013, 12:18 PM
ZeeJay1997
Do you have meter and know how to use it? If so, do this
ZeeJay1997 is offline
post #20 of 40 Old 07-29-2013, 12:25 PM Thread Starter
cryptic3
I dont have a meter
cryptic3 is offline
post #21 of 40 Old 07-29-2013, 02:39 PM
dnuccio
rebuilt battery? how the hell do you rebuild a battery?
id buy a brand new battery
R.I.P. Ratmonkey
dnuccio is offline
post #22 of 40 Old 07-29-2013, 02:44 PM
zjosh93
Usually "rebuilt" batteries are cores or used batteries that the shop puts on a charger and load tests. If they pass they clean them up and sell them as rebuilt. In Texas you have to call them "used". It's a crap shoot though. A lot of batteries get replaced that are perfectly good but you also get marginal batteries that can pass the load test right off the charger but will not last in a car.
Agreed though, I'd never touch a used or rebuilt battery. Always buy new. Also be aware that 90% of the batteries you see on the shelf are made by Johnson controls so it doesn't matter if you buy an Autozone, Napa, OReillys, Advanced, or Walmart battery. They are all identical.
zjosh93 is offline
post #23 of 40 Old 07-29-2013, 03:10 PM Thread Starter
cryptic3
Thanks zjosh93... I know it was a risk just thought Id take a chance and test my luck guess this time I had none.... ill get a brand new battery and see if that will work I might buy battery cables but I dont know hiw to change them out.
cryptic3 is offline
post #24 of 40 Old 07-29-2013, 04:39 PM
ZeeJay1997
I dont have a meter
Meters are a prerequisite to owning a ZJ. Anyone who doesn't have one must sell their ZJ and start over.
post #25 of 40 Old 07-29-2013, 04:46 PM Thread Starter
cryptic3
Was that necessary?
cryptic3 is offline
post #26 of 40 Old 07-29-2013, 06:02 PM Thread Starter
cryptic3
But your right I need tools im not a mechanic im a computer nerd. But I have my jeep and my wife has a van.... I want to get into to this and fix my own vehicles thats why I come to you guys
cryptic3 is offline
post #27 of 40 Old 07-29-2013, 06:28 PM
ZeeJay1997
Was that necessary?
No, but a meter is if you want to save yourself some cash while owning a ZJ. It wasn't a personal attack, just an attempt at sarcastic humor.
Honestly, If you have the smarts to be a computer / IT / software type, you have the ability to use a meter and inerpret the results. Without one you are just guessing and, in most cases, so is everyone else who may offer advise. You can pick a cheap one up for around 15-20 bucks. You can get that back by ruling out one sensor you would have otherwise changed. They are good to have for other household stuff too.
There are some things you can do without them, like give everything a good cleaning and inspection, and you need a basic set of tools for that.
There are some good youtube videos that give instructions on basic troubleshooting of charging systems and most of them involve using a meter. So does the link I provided earlier.
You might get lucky and replace the battery and all will be well. If not it will take some troubleshooting to figure out what's really wrong with it.
post #28 of 40 Old 07-29-2013, 09:00 PM
dnuccio
makes sense. id never touch a used battery either, not with a 10 foot pole
R.I.P. Ratmonkey
dnuccio is offline
post #29 of 40 Old 07-29-2013, 09:10 PM Thread Starter
cryptic3
Ok ok i Learned my lesson. Never buy used batteries. Did another test. Let the car run for about 20 minutes then I disconnected the battery and in the morning ill reconnect it and see if its dead. Only thing I can do till paid day so I can get a volt meter
cryptic3 is offline
post #30 of 40 Old 07-30-2013, 07:12 AM Thread Starter
cryptic3
So after reconnecting, it barely had enough juice to turn over but it did. I turned it off as I realized the negative cable wasnt screwing on tight after some rethreading I put the battery back in made sure everything was tightened. Went to turn her on...... and didnt have enough juice to turn on.... so does it sound like its the p.o.s. battery that I bought for $25 thats crap? I boosted up the battert let it run for 20 minutes, then disconnect both terminals over night in the morning this was the resukts5
cryptic3 is offline
