battery or alternator - JeepForum.com
post #1 of 40 Old 06-30-2013, 04:25 PM Thread Starter
cryptic3
So my battery dies I get a boost and starts right up... Let it run for a bit turn off and it turn on right away but if I let it sit there for a couple hours its dead... Could this be the battery or alternator... And I don't think I'm leaving any lights on or anything else?? Any clues or tips?
cryptic3 is offline
post #2 of 40 Old 06-30-2013, 04:30 PM
DustyROADD
Start the jeep and take the negative off of your battery. If it dies then your alternator is bad.
DustyROADD is offline
post #3 of 40 Old 06-30-2013, 04:37 PM
Oldfrog
2007 WK
I'm not sure that's correct....and I would never remove a battery cable on a vehicle with these type of electronics while it's running. You'll probably be buying a new PCM if you did.
Get the battery load tested.Check out the alternator and all the battery connections. Dont just look at them...remove them and clean them.
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
post #4 of 40 Old 06-30-2013, 04:43 PM
a70eliminator
Your battery is loosing charge, it's bad, you need a new one.
a70eliminator is offline
post #5 of 40 Old 06-30-2013, 04:56 PM Thread Starter
cryptic3
Yeah I read that taking off the negative cable can cause a shortage and damage the computer components. I've clean the battery cables a few months back I rechecked them they are fine. Guess I'll go and get the battery tested
cryptic3 is offline
post #6 of 40 Old 06-30-2013, 05:32 PM
dnuccio
NEVER take off a battery cable with the engine running. you'll fry the PCM. if it starts after you get a boost, and starts again shortly after you turn it off, your alternator is working fine. its the battery
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #7 of 40 Old 07-02-2013, 10:50 AM Thread Starter
cryptic3
I unplugged my battery when I got home after work in the afternoon and I disconnected the cable wires from the battery and this morning I connected them back and it was dead.... Thanks for the tip guys
cryptic3 is offline
post #8 of 40 Old 07-02-2013, 11:45 AM
um7267
voltmeter should read 13.3-14.7 at start up, and after its running it should settle to 13.7
if the alternator is dead it would read 12.28+/- and be dropping
2004 Lexus Es330, alive; 1999 Cherokee Sport
1998 Grand Cherokee, sold
1997 Grand Cherokee; Black and Gold, Limited 4.0....RIP 2005
to the good times and the bad, the family we have and lost, little brother 1988-2011
um7267 is offline
post #9 of 40 Old 07-02-2013, 11:58 AM Thread Starter
cryptic3
Yes I checked the voltmeter the battery doesn't hold a charge it was a battery from Walmart... The sticker says 1/07 that was 6 years ago.... Wonder if I should go back to Walmart and get another battery from there... However I went to auto zone online and put in my jeep specs and it say my jeeps recommended CCA is 800 but that battery is 650 CCA ?????
cryptic3 is offline
post #10 of 40 Old 07-02-2013, 12:37 PM
AaronButler
Ive had good luck with Batteries from Autozone. I did have one go bad about a year and a half after I bought it, but when I went in (fully expecting to just buy a new one) they replaced it free of charge.
1996 ZJ 4.0 Laredo... you know, the one with the ripped leather seats
AaronButler is offline
post #11 of 40 Old 07-02-2013, 12:40 PM
zj97ltd
I think 6+ years is pretty good in a ZJ. My '97 Orvis ate batteries. I think the heat got to them. The Wal-Mart yellow ones had a 3 year warranty, and they'd never last that long. BUT they never gave me a hassle replacing it.
zj97ltd is offline
post #12 of 40 Old 07-02-2013, 01:44 PM
PolkaPower
If the battery was dead then you jumped it to start it will not be anywhere near charged enough by the alternator to start again later. If your battery dies you need to put it on a trickle charger over night. You could drive it around all day and the alternator will not come close to fully charging a battery.
PolkaPower is online now
post #13 of 40 Old 07-02-2013, 08:10 PM
dusterdude
Your wm batt is 6 years old,you should frame that sucker.6 years is damn good life out of a batt
dusterdude is offline
post #14 of 40 Old 07-02-2013, 08:13 PM
Mickey_D
This.
The expected life of a car battery is 3 to 5 years. If you got 6 years out of a Walmart Special, you did good man.
1997 ZJ 5.2 Orvis, Baby!
1953 Willys M100 trailer Tagalong
________________
[_][][][][][][][][_]
#4
Mickey_D is offline
post #15 of 40 Old 07-02-2013, 08:26 PM Thread Starter
cryptic3
Lmao wow I feel honor like if I did something awesome Lol I think the battery is to heavy to frame I'll take a picture instead
cryptic3 is offline
