Battery/ altenator problems? - JeepForum.com
post #1 of 11 Old 03-08-2013, 10:02 AM Thread Starter
joshy_squash81
I put a new battery in my ZJ back in November so I could move it into the garage and I didn't touch it until about a month ago, its Maine so its been cold so I understand that if you let it sit for 2-3 months it would drain the battery but the last couple days it takes about 15 minutes to jump-start it using my truck then I let it run for about 15 minutes, then I go back about 30 minutes later and it starts fine and I let it run some more but I go out the next morning and the battery is completely flat so I'm not sure whats going on here, there isn't anything drawing power that I know of so I was thinking the altenator but I don't know what do you guys think? I love it but this thing has been a pain in my *** lately.
joshy_squash81 is offline
post #2 of 11 Old 03-08-2013, 10:52 AM
PolkaPower
You need to put the battery on a trickle charger overnight and test it with a multimeter. Just running it for 15 minutes won't charge it. Driving it for a full day wouldn't even charge it all the way.
PolkaPower is online now
post #3 of 11 Old 03-08-2013, 11:19 AM
Impulsive94ZJ
1994 ZJ
PolkaPower is exactly correct. I just went through this with my 94' after letting it sit for months with a blown trans. After jumping it a couple of days in a row I finally pulled the battery, put it on a trickle charge until its over 40% then switched to a higher charge until 100%. I have not have anymore problems.
94' ZJ 99' Leather, 3.5" Lift, 33" - 01' WJ 2.5" Lift, 32" on 18" Wheels - 02" WJ 4" Lift on 33's
Impulsive94ZJ is offline
post #4 of 11 Old 03-08-2013, 11:33 AM
JS97ZJ
A fully charged battery will only last 20 days due to the draw from the memory functions.
Like Polka said you need to fully charge it on an external charger overnight to get it back up to full charge. The generator is only in there to maintain what is being drawn off the battery during normal operations. It isn't a charger.
If you don't use the Jeep that often, disconnect the battery and get one of those inexpensive trickle chargers to maintain it. The battery will go bad if you repeatedly discharge if too many times.
If it drains overnight or within a 2 day period you have a parasitic draw.
JS97ZJ is offline
post #5 of 11 Old 04-04-2013, 12:51 PM
Meik
How could I find the draw, my 96 Grand has been running fine, yet sat for three days and it's flat.
Meik is offline
post #6 of 11 Old 04-04-2013, 09:51 PM
dylantheheeler
Get out your multimeter that can read amps. Disconnect positive cable from battery and position it away from positive post. Set meter to low amp setting, you're checking for milliamps here. Hold positive meter cable to positive post on battery. Hold negative meter cable to positive cable from jeep. Now that the circuit is completed your meter should show no more than about .035 amps. If it is a lot higher, start pulling fuses one by one until it drops. Start with a fully charged battery.
yo vivo. yo voy. yo soy. Jeep.
I live. I ride. I am. Jeep.
dylantheheeler is offline
post #7 of 11 Old 04-05-2013, 12:43 PM
Meik
Pulled te battery out and have it on charge. Hopefully get to marplins tomorrow and pick up multimeter
Meik is offline
post #8 of 11 Old 04-07-2013, 12:47 PM
Meik
So I pulled the battery out, charged it over night,then put it ack in, following day dead as a dodo so guessing the battery is mullered.
Meik is offline
post #9 of 11 Old 04-07-2013, 06:53 PM
dylantheheeler
Sounds like it. A new one is cheap enough insurance over getting stranded.
post #10 of 11 Old 04-07-2013, 08:18 PM
kensnelling
I never heard the term "mullered" before, but I presume it means bad. Not a good presumption to make.
You need to charge the battery again fully, then take it to be load tested. They'll do that at the place you bought the battery from to confirm a bad battery before warrantying it out.
If the battery checks out good then take it home and do a current draw test on your Jeep. I won't go through the procedure here, Google it and you'll get hundreds of hits telling you how to do a draw test.
Ken
kensnelling is offline
post #11 of 11 Old 04-13-2013, 06:04 AM
Meik
Ken
One new battery installed , tested it and it's reading 12.6 volts, disconnected the positive cable and checked for drain didn't read anything so that's good hopeful,y was just a duff battery.
Meik is offline
