Bar pin eliminator specs - JeepForum.com
post #1 of 7 Old 06-29-2013, 01:24 PM Thread Starter
coltman151
Was given some shocks for my zj that will fit my budget boost better. The only problem is they aren't bar pin shocks.
I've got some 1/8th and some 1/4 steel here. I can bend the 1/8th within my shop, but the 1/4 will require me to find someone to do it.
My question is will 1/8th steel hold up? Or do I need to wait and get the 1/4 steel bent for my zj. All I'm going to do is take the plate and put two bends in it and drill holes. It will be about 4 inches by 2 inches. I've seen a few bpes that are 1/8th but none that are resold and it kinda has me leery of doing it.
Thanks in advance.
95 Laredo 4.0, 2" RE BB, RC N2.0 Shocks, Custom Roof-Mount Light Bar w/ 6 lights, Bumpers deleted, Homemade sway bar discos, Michelin LTX 31x10.50s, and a Dog Box :)
Planned: Homemade Spare tire carrier, double shear front track bar, 4 adjustable rear control arms, New Rims and 33" Wrangler MT/Rs or BFG M/T KO's w/ LOTS of trimming.
coltman151 is offline
post #2 of 7 Old 06-29-2013, 03:53 PM Thread Starter
coltman151
Bumpity
post #3 of 7 Old 06-29-2013, 03:57 PM
Dyn0mitemat
I'm confused why you need to bend anything, can you not just put a hole in two pieces of plate and weld them on?
09 Rubi 2dr:MetalCloak2.5", 37"MTZ's/Slabs, EVO Stff, ORFab Cage, Chromo's, Driveshafts etc
Dyn0mitemat is offline
post #4 of 7 Old 06-29-2013, 05:11 PM Thread Starter
coltman151
No welder
post #5 of 7 Old 06-29-2013, 06:15 PM
a70eliminator
I guess that's a good reason. actually the 1/8 steel L's should be plenty strong, the forces are only the shock compression itself.
The illustration above looks to be nothing more than 1/8" only it's welded rather than bolted, you'll be fine.
3/16 would certainly do it and 1/4 is overkill.
a70eliminator is offline
post #6 of 7 Old 06-29-2013, 07:27 PM
Dyn0mitemat
Close, 3/8" on what I did.
And they have force exerted on them in both directions (not just compression) but 1/8" would probably be ok considering they're mounted to sheet metal with the factory mounts
post #7 of 7 Old 06-30-2013, 11:41 AM Thread Starter
coltman151
Thanks. I'm not gonna be rock bouncing in it so ill try the 1/8th. If it starts to warp or bend, we will beef it up
