Bank 1 Sensor 2 '01 Grd Cher o2 sensor location - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Bank 1 Sensor 2 '01 Grd Cher o2 sensor location
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.comBUMPERS by Rough Country! SOLD at ROCKRIDGE 4WD!! AWESOME
Unread 02-04-2009, 02:13 PM   #1
mgrean
Hello-
My check engine light has been on for a while but recently my 01 Grand Cherokee (v6,4wd) started having idling problems after the car got warmed up. I took it to autozone to have the code read and I got PO138 and PO 141. 138 defines the problem as "H02S 12 circuit condition (heated oxygen sensor bank 1 sensor 2)" and the 141 definition is essentially identical. I picked up a new sensor today and when I got under the jeep I had no idea which sensor was bad. There is a dual exhaust so both sensors are right after mini catalytic converters, then the pipes join into the exhaust tube and head toward the rear. Is there anyway to figure out which is which or am I going have to trial and error?
Thanks, Mark
mgrean is offline   Reply With Quote
Unread 02-04-2009, 09:37 PM   #2
irishmarco
Guessing V8 here...bank 1 is the side cylinder 1 is on, just don't know off-hand on this motor. (sensor 2 is after-cat). I'll try a search and get back to you. Codes will need to be cleared after fix. Good idea to go ahead and soak threads with penetrating oil, not when hot!
'04 WJ Laredo 4.0L selectrac, 99k, 2.5" Rusty's coils
'89 YJ Wrangler S 2.5L (60K), 2" Rusty's AAL, 31" BFG
'90 Miata (30 mpg DD) 220K, '01 engine (27K)
sold : '95 XJ country, 4.5" RE, 31" BFG, F&R lockers
sold : '01 WJ 4.7L Limited, really wanted to lift! (wife)
irishmarco is offline   Reply With Quote
Unread 02-04-2009, 09:40 PM   #3
gatorayde
You have the I6, not V6.
gatorayde is offline   Reply With Quote
Unread 02-04-2009, 10:07 PM   #4
irishmarco
You could replace one sensor, disconnect battery to clear codes, reconnect and drive until light comes on (or doesn't). If light comes back, put old sensor back and replace other. Easy to do, 5 minutes if you soaked rust with oil! Be careful not to damage new sensor when swapping.
Unread 02-05-2009, 06:58 AM   #5
rm2001wj
Originally Posted by mgrean View Post
Hello-
Thanks, Mark
Sensor 2 is a sensor after a minicats. (Sensor 1 is in front of a minicat, so you have two Sensor 1s along with the two Sensor 2s.) For your I6, Bank 1 is the first (at the front, closest to the radiator) three cylinders while Bank
2 is the last three cylinders. Bank 1 Sensor 2 is the sensor after the minicat closest to the front of the engine.
The CA emissions diagram at this URL will make this clear. http://www.wjjeeps.com/oxygen_40.jpg
2001 WJ Limited with Quadra-Drive, Kenne Bell Supercharger, 3-inch Kolak exhaust, Stillen rotors (F/R) and MM pads, Addco sway bars (F/R).
rm2001wj is offline   Reply With Quote
Unread 02-05-2009, 07:23 PM   #6
irishmarco
Figured the "dual exhaust" was each manifold on the V8, oh well....never studied the exhaust on my XJ (4.0).
Unread 02-05-2009, 08:29 PM   #7
wonderbrd937
i have the same code p0138 and i had picked up the bosch oxy sensor, hopefully the light goes off
99 WJ 4" SA lift
rolled fenders
35" bfg km2
tons of fabrication
wonderbrd937 is offline   Reply With Quote
Unread 02-05-2009, 08:35 PM   #8
the88thpianoman
the88thpianoman's Avatar
2003 WJ
Return it and get a mopar.
WJ front drive shaft and fuse panel for sale
2003 WJ in Jeep Green Metallic, 4.0/242/4.10's. 4" Teraflex springs w/ RE monotube shocks and IRO short arms, cheap intake w/ amsoil filter, 2.5" hi flow cat and back exhaust, lots of lights and other misc crap.
Check out my build thread here: Life lessons and budget build
the88thpianoman is offline   Reply With Quote
Unread 02-05-2009, 08:36 PM   #9
wonderbrd937
ill have to pass on that, my pockets aren't filled with money, and i have to see if i need it first, im going to take it out and clean it.
99 WJ 4" SA lift
rolled fenders
35" bfg km2
tons of fabrication
Unread 02-05-2009, 08:38 PM   #10
the88thpianoman
2003 WJ
Getting the mopar sensor from kolak will cost maybe ten bucks more. Don't install the bosch, then you might not be able to return it and you'll be out that much more money once you've bought both. Trust me on this... others on here will tell you the same: Jeeps do not like bosch O2 sensors. Return it.
Unread 02-05-2009, 10:15 PM   #11
mgrean
from the general consensus here I will say I regretfully already bought and installed the bosch sensor. I have not disconnected the battery/reset the computer, but the problem has not gone away. tomorrow I will reset and then try swapping the sensors if they still read the same.
also, as the jeep is struggling to stay alive the lights dim and brighten with the rpms. I would guess this to be an alternator problem but the new battery checks out and I had the alternator tested a few days ago and it's apparently fine. thoughts?
thanks, mark
Unread 02-06-2009, 05:57 AM   #12
kentman
2006 XK Commander
CA emissions suck. It is just a bunch more crap to go bad and cause pain and suffering down the road. Who ever heard of four O2 sensors on an I6? That is crazy. Why not just have twelve O2 sensors, two for each cylinder. That could make our air quality better.
When I bought a Bosch for the WJ (Bank 1 / Sensor 2 on the 4.7L HO), it was completely the wrong size. I returned it and bought a Mopar one. That one fit perfectly.
Regarding power, you could check the belt and the ground connections. You could even have water or PS pump problems slowing the belt down or making the belt slip. Check the tension, too.
Kent
'06 XK Limited, 5.7L Hemi, Quadra-Drive II, Black, 107K Miles
'02 WJ Overland, 4.7L HO, Quadra-Drive, Inferno Red, 92K Miles
kentman is offline   Reply With Quote
Unread 02-06-2009, 09:18 AM   #13
mgrean
after searching through the forums a bit, the following seem like likely culprits...
1. throttle position sensor
2. idle air control
3. vent control\vacuum leak
4. egr valve vacuum line.
one of the codes read before said I had a vacuum leak, and one of the other threads stated the exact same problem I have was fixed by fixing the egr valve. however, after looking in my Haynes manual, my model does not have an egr valve. so, back to the drawing board.
Unread 02-06-2009, 09:21 AM   #14
mgrean
forgot to mention, regardless of the setting, air only blows out of the defrost vent.
Unread 02-06-2009, 09:25 AM   #15
QuadraTokn
1930 WJ
Ronnie, Listen to the other guy. I had a Bosch sensor once and - no joke - It ran as good as a bad OEM sensor.
And dont even try cleaning it, it wont work.
QuadraTokn is offline   Reply With Quote
