Ball Joint Removal / Installation CORRECT Tool? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Ball Joint Removal / Installation CORRECT Tool?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineToxic Brakes - 3000 PSI Braided Stainless Steel Brake LineCess Recovery Gear Snatch Tow Strap OffRoad @ ROCKRIDGE4WD
Unread 03-27-2014, 05:37 PM   #1
Zakimations
I searched everywhere and could not find a definitive answer.
There are a lot of ball joint write ups but I do not feel like any of them mention which removal / install tool they are using.
I understand the correct ball joint press for the application has to have special angled adapters in order to press them in straight.
The POS rentals from the local parts store are definitely not adequate.
Anyone have any advice? part numbers at least?
Zakimations is offline   Reply With Quote
Unread 03-27-2014, 05:54 PM   #2
JasonStebbins
The press from the local parts store works fine for me. What are you having trouble with?
This guy has a three video process on how to do it.
https://www.youtube.com/watch?v=_EMBVkCLpo0
JasonStebbins is offline   Reply With Quote
Unread 03-27-2014, 05:59 PM   #3
CJ7-Tim
Real Jeeps have dents.
CJ7-Tim's Avatar
Ball joints can be done without the Chrysler/Jeep adapters, but the adapters do make the job faster and less frustrating.
According to the National Shooting Sports Foundation, AR-15 sporting rifles account for nearly 20% of all U.S. firearms sales.
Progressive Liberalism: Bringing you new Healthcare ideas so wonderful, they have to include mandatory participation ......
Originally Posted by Ronald W. Reagan: Government is not the solution to our problem; Government is the problem.
CJ7-Tim is offline   Reply With Quote
Unread 03-27-2014, 08:08 PM   #4
Zakimations
Part 2 @ 9:00
Notice his wide variety of ball joint adapters.
Unread 03-27-2014, 08:20 PM   #5
JasonStebbins
Didn't even notice.
I just rented the ball joint press (has 3-4 different "cups" and 3-4 different bases) and had no problems with alignment when installing. They go in pretty easy if you clean/grease the knuckle. I just used a 1/2" ratchet with a cheater bar and had no issues.
Unread 03-27-2014, 10:32 PM   #6
1998_ZJltd
if you have any lift on your zj you could look into adjustable ball joints ... they give you a bit more adjustment on top of the adjustment in the arms w the cam bolt ....
1998_ZJltd is offline   Reply With Quote
Unread 03-28-2014, 12:06 AM   #7
bobinAZ
I just did mine last week. Rented the press AutoZone had. It worked ok. I did have to fangle the cup for the lower BJ removal, the cup was pinching between the knuckle and the ball joint. If the cup was notched it woulda been a lot easier. Imho.. I think some cups come that way.
I guess what I'm saying is if I could find a adapter set that had those for $20/30 bucks I would buy them and then rent the kit from your parts store..
I'm stuck in the "why not cycle" Since i have to do, A & B "why not" do C & D while I'M at it.
bobinAZ is offline   Reply With Quote
Unread 03-28-2014, 12:38 AM   #8
mdelosrey
I've used this clamp with various adapters. Don't forget to wear eye protection.
http://www.summitracing.com/parts/oe...FUWVfgodkmEAwg
mdelosrey is offline   Reply With Quote
Unread 03-28-2014, 03:55 AM   #9
coralman
coralman's Avatar
This might help. Balljoints start at post4.
http://www.jeepforum.com/forum/f13/c...build-1518536/
Move over bear.I'm tired of working on the jeep
coralman is offline   Reply With Quote
Unread 03-28-2014, 05:59 AM   #10
Technohead
Old School
Technohead's Avatar
I recommend the OTC press with D30 adapters. I've seen many guys screw up their outer C's because they were not using the proper adapters.
Technohead is offline   Reply With Quote
Unread 03-28-2014, 08:40 AM   #11
Muskitokid
1994 ZJ
I just did mine recently with the tool from O'reilly. Had to improvise a bit to accomodate the angle (used the edge of a washer to fill the gap) but got it done none the less. And I'm still learning as I go on this diy repair stuff. Between JF and youtube, you can do it!
Muskitokid is offline   Reply With Quote
