I am installing new ball joints on my 97 Gr. Cherokee. The lower one went in fine, but the upper one went in way to easy? After installing the upper I went to put in the grease nipple and the whole ball joint turned in it’s seat?!?!? I made sure that the BJ is pushed all the way in. I also had the parts store check twice to make sure they sold me the correct BJ.
This is not good right?
Any ideas what my next move is?
Also while I have it all apart I checked for play in the hub, and I do notice a slight wobble (play). Should I replace that as well while I have it apart, or is a slight bit normal?
