Baja Ryder with offset hoop or monotube? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Baja Ryder with offset hoop or monotube?
FREE, FREE, FREE EVENT!! Save big on Lockers now till ApriJKS Jspec Suspension BLOW-OUT FEBRUARY ONLY!! HURRY UP!Income tax season is upon us. We got what u need
Unread 07-12-2011, 09:55 AM   #1
Scottso699
2006 WK
Does any one have any experience with these? I have regular old shocks right now and they are hitting the spring perch and have dented the shocks (lovely... right?) These have offset hoops and look like they might help. But for $50 I was looking at Rough Country's mono tubes which are about $50 and are inverted and would solve the problem too.
Any opinions?
Scott
2006 WK Overland
2014 WK2 Limited
Scottso699 is offline   Reply With Quote Quick reply to this message
Unread 07-12-2011, 09:57 AM   #2
speedbucket
post a pic, i am not following how you dented the shock with the spring perch
http://www.jeepforum.com/forum/f22/speedbuckets-zj-build-1361322/
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline   Reply With Quote Quick reply to this message
Unread 07-12-2011, 10:02 AM   #3
Scottso699
2006 WK
I am at work so I don't have the jeep handy, but because I have the pinion pointed up because of the SYE kit the spring preach in the rear contacts the back of the shock when you are at full flex. Has a nice dent now. I will post a picture tonight.
Scott
2006 WK Overland
2014 WK2 Limited
Unread 07-12-2011, 10:10 AM   #4
speedbucket
oh, you didn't specify it was the rear, i was thinking front.
moving the shock rearward frameside might change the feel bc they are already angled back pretty good. maybe weld an extension bracket back a little farther than the stock axle side? or do a resevoir shock as they seem to have a smaller diameter
Unread 07-12-2011, 10:17 AM   #5
Scottso699
2006 WK
That's what I was thinking too - get a mono tube as the shock is inverted and the body will be up at the frame rather than the axle end.
Scott
2006 WK Overland
2014 WK2 Limited
Unread 07-13-2011, 08:41 AM   #6
ratmonkey
R.I.P.
ratmonkey's Avatar
get a monotube and run it the proper way(inverted)
ratmonkey is offline   Reply With Quote Quick reply to this message
Unread 07-13-2011, 08:46 AM   #7
Scottso699
2006 WK
That's the way I am leaning. Attached are two pictures of my problem.
Scott
2006 WK Overland
2014 WK2 Limited
