Baffling air conditioning/ATC problem - JeepForum.com
post #1 of 1 Old 04-16-2011, 08:46 PM Thread Starter
pba7498
95 GC limited w/ATC
This all happened in about 2 seconds. While driving I noticed a noise from the blower motor, looked down at the area, saw some smoke coming from that area, reached for the a/c controls, saw the temperature readout flicker and go out before I could turn it to the off position.
Since then this is what I have done. I have purchased a new(used) control module, a brand new oem power module(resistor) and a new blower assembly. I have tested the new blower and it works, even the old one works, but I changed it for the heck of it. I can only assume that the new resistor works because I don't know of any test to perform on it. I disassembled and removed the dash and evaporator module looking for burned wires/connectors, tested for continuity on ALL the wiring and all tested good. Couldn't find anything, I even untaped the entire harness for visual inspection...nothing. Verified all relays and fuses as well. Reassembled everything hoping for the best and nothing changed. I've run out of ideas. Possible PCM issue? Maybe there is a bad ground somewhere? Does anybody have a wiring diagram for this?
It really sucks driving this GC with no a/c......
pba7498 is offline
air conditioning , wiring diagram
Weird ZJ Air conditioning problem DothanJeep ZJ Grand Cherokee Forum 8 07-28-2012 03:57 PM
Baffling Quad-Drive transmission problem cfmcgrath ZJ Grand Cherokee Forum 0 12-10-2009 08:56 AM
Weird Air Conditioning Problem... 5point9Limited ZJ Grand Cherokee Forum 11 05-30-2009 11:50 AM
93 Air Conditioning problem with pressure eBoyDog ZJ Grand Cherokee Forum 12 04-20-2009 12:19 PM
Air conditioning problem A4x4Junky ZJ Grand Cherokee Forum 10 06-03-2006 05:37 AM
