Bad Wheel Bearing? - JeepForum.com
post #1 of 5 Old 10-16-2010, 09:24 PM Thread Starter
purplecty
2003 WJ
Bad Wheel Bearing?
what are the symptoms of a bad wheel bearing? i have a loud howl/hum coming from front end. seems to get a lot louder at higher speeds. very loud can barely hear radio on HWY. it is constant whether stepping on gas or not it just stays howling/humming. can this be bad wheel bearings? 2003 WJ 4.0 136,000 miles
purplecty is offline
post #2 of 5 Old 10-16-2010, 10:28 PM
soul_Less
1994 ZJ
on my zj, it kinda sounds like you're driving over rumble strips on the highway..
soul_Less is offline
post #3 of 5 Old 10-16-2010, 10:56 PM
TallyZJ
Lift the front end off the ground. Roll each wheel by hand and feel for a gringing/rubbing/notchy feel. Listen for noise.
Grab the tire by the top and the bottom and shake back and forth (to the inside and the outside) and feel for a clunk or some play.
1996 Jeep Grand Cherokee Laredo 4x4 - 4.0L
TallyZJ is offline
post #4 of 5 Old 10-17-2010, 12:47 AM
paddingtonbear
At least in my case there was a noticeable change in the driving and handling, my wheel bearing blowing caused death wobble, the lift and shake method works, if you do tight corners in a parking lot you feel it click, grind, or steering vibes thats another way to check, that is what mine was doing and how it was diagnosed.
JEEP ZJ-
3.5 inch lift
(all the steering goodies/upgrades)
Crager soft 8-32x10.5x15 AT
Kevinsoffroad Radiator support/tow hooks
Kevinsoffroad Sliders
paddingtonbear is offline
post #5 of 5 Old 10-17-2010, 07:47 AM Thread Starter
purplecty
2003 WJ
i do notice a click in the steering wheel. but it seemed like something in column. always thought it was like just something loose in the steering wheel. could i have a bad wheel bearing?
Sign of a Bad Wheel Bearing or Ring and Pinion Bearing? torchd ZJ Grand Cherokee Forum 28 02-15-2014 08:14 AM
wheel bearing BigItalianBeast ZJ Grand Cherokee Forum 13 05-29-2012 04:15 PM
Wheel Bearing??? 01grandjeep ZJ Grand Cherokee Forum 9 11-22-2007 04:55 PM
wheel bearing vs axle bearing. cifer6425 ZJ Grand Cherokee Forum 5 06-21-2007 01:04 PM
Wheel Bearing?? Clifford97GC ZJ Grand Cherokee Forum 2 01-09-2007 07:04 PM
