bad vibration at about 50-65 mph - JeepForum.com
post #1 of 25 Old 03-01-2010, 06:38 PM Thread Starter
teg_ls
i have a 1993 GC with 3 inch spacers and a 1 inch t-case drop and i get a bad vib. on the high way...what could it be??
teg_ls is offline
post #2 of 25 Old 03-01-2010, 06:53 PM
SplitNail
Tires, drive shaft that needs to be balanced. Have you done anything lately that could have bent the DS or maybe bent a wheel.
1999 WJ 4.7L V8, 242 TC, Front Aussie Locker, 4 Inch RC X-Series lift, 17x8 w/ 4.5BS Black Rock Vipers, 285/70/R17 BFG KM2's, All AMSOIL Synthetic Fluids
SplitNail is offline
post #3 of 25 Old 03-01-2010, 06:57 PM Thread Starter
teg_ls
i have 33inch tires on it...when the front drive shaft is out its fine??
teg_ls is offline
post #4 of 25 Old 03-01-2010, 07:00 PM
SplitNail
Then it could be bad CV on the driveshaft if you have that or u joints on the driveshaft.
post #5 of 25 Old 03-01-2010, 07:02 PM Thread Starter
teg_ls
thats what i just had done on it...could it need the t-case droped more??
teg_ls is offline
post #6 of 25 Old 03-01-2010, 07:02 PM
SplitNail
Do you have a CV or Ujoints on the DS?
post #7 of 25 Old 03-01-2010, 07:09 PM Thread Starter
teg_ls
man i really dont no i no its different at each end...one end just has a " + " looking thing witch i think is a u joint and the other looks a little bit more crazy...lol
teg_ls is offline
post #8 of 25 Old 03-01-2010, 07:12 PM Thread Starter
teg_ls
its the third one down
1993 Jeep ZJ. 4.0
teg_ls is offline
post #9 of 25 Old 03-01-2010, 07:13 PM
SplitNail
Does the front of the DS look like this?
post #10 of 25 Old 03-01-2010, 07:14 PM
SplitNail
Im thinking bad ujoints.
post #11 of 25 Old 03-01-2010, 07:41 PM Thread Starter
teg_ls
if thats not it what els do you think it could be....i just had new ones put in
teg_ls is offline
post #12 of 25 Old 03-01-2010, 07:44 PM
SplitNail
Tires out of balance. When did you last rotate and balance them?
post #13 of 25 Old 03-01-2010, 07:49 PM
T-birdJunkie
2002 KJ Liberty
check U-joints for play - sorry, responded before reading the thread
T-birdJunkie is offline
post #14 of 25 Old 03-01-2010, 08:04 PM Thread Starter
teg_ls
if it was the tires it would do it even with the drive shaft out...right?? i think its somthing to do with the front axle or like you said the ds
teg_ls is offline
post #15 of 25 Old 03-01-2010, 08:06 PM
sadass
Has this just started after a lift? I would say tire out of balance if it goes away above 65 , or at least diminishes. But you say it is fine with front drive shaft off, so that brings me back to my first question, Here is the problem with the drive shaft you have, It is a prop shaft or CV style shaft. the Length is factory set. It does not allow for the different lenght you now need due to the lift like say a U-joint with the slip type Yoke. I am not sure if it will work with 3" / 4" and I know we all start to have issues with that prop shaft. It is a tough one. so first try to rotate the tires front to rear, and defiantly check your tie rod ends as mention. at least to be safe. Then it is back to the front drive shaft being the culprit. find out what was done to it. and was it good right after the rebuild or replacement of you new one?.
5NineZJ,35mtr/k IRO 7" LA F/R Detroit F/HP-4.56 R/Aussie 44A. ARB Snorkel/JRC Sliders/ Protofab w/9500S./Bushwhackers. Novak242 TCcable.
sadass is offline
vibration rmtomasin ZJ Grand Cherokee Forum 11 03-26-2009 10:40 PM
vibration driabyor ZJ Grand Cherokee Forum 5 06-23-2005 10:24 PM
I6 vibration... CBlakeNS ZJ Grand Cherokee Forum 13 04-20-2005 10:43 PM
Vibration at 65+ MPH ats1968 ZJ Grand Cherokee Forum 1 02-13-2005 12:15 AM
vibration 01grander ZJ Grand Cherokee Forum 3 01-18-2005 08:34 AM
