Bad U-Joint? *Pics* PLEASE HELP! 5.9 ZJ - JeepForum.com
post #1 of 11 Old 11-14-2013, 03:03 PM Thread Starter
5point9Limited
5point9Limited's Avatar
Hey guys, I have been chasing a vibration that is coming from what seems like the rear of the ZJ. It is way more prominent during acceleration at a range of speeds. I don't feel anything in the steering wheel.
So far I:
-Rebalanced the rear tires
-Had a new hanger welded onto the exhaust because it was loose
-Replaced the transmission mount
Still have the exact same vibes. I did some more searching and it led me to take a closer look at the U-Joints. I see metal exposed in the one section of the U-joint. It looks like it separated a little bit.
Can any of you tell me if you see anything wrong just from the pics?
If it is the U-Joint, where should I get a replacement part?
1997 TJ 4.0, 5 Speed, Stock
Sold: 1998 Grand Cherokee 5.9 Limited
5point9Limited is offline
post #2 of 11 Old 11-14-2013, 03:33 PM
kensnelling
From the pics I can't tell if it's bad, just see the dust shield has moved. Usually with a bad u-joint you will hear a clicking noise. Did you grab the driveshaft and see if there was any play in the joints?
Ken
kensnelling is offline
post #3 of 11 Old 11-14-2013, 04:00 PM
RWC
A clicking is more likely to be a front u-joint (an axle shaft u-joint in particular).
You'll get a bad vibration under acceleration with a rear driveshaft u-joint, so I agree that this is the likely culprit. Put the parking brake on and the transmission or t-case in neutral (with the engine off so you don't accidentally drive over yourself) and crawl under there. Grab the driveshaft near the u-joint and try to rotate it and wiggle it back and forth. If there's any play AT ALL, then the u-joint is bad.
Replacing a u-joint is a good learning experience. Go to your local parts store and buy a new u-joint. If you're careful and don't bend the ears, you can replace it with just a hammer, a socket, and a pair of pliers. It's easier to do it with a good vice or a press. Search for a thread with instructions.
Assuming that your screen name reflects your ZJ, when you hit up your local parts store, make sure to specify that you've got a 'Niner. The 5.9L came with a larger rear u-joint than the 5.2L.
RWC is offline
post #4 of 11 Old 11-14-2013, 05:58 PM Thread Starter
5point9Limited
Thanks, boys. I did try to move the driveshaft, but it was in park and it didn't really move much. I'll try it in neutral tomorrow. I did do some homework on replacing the part and it definitely seems doable. Thanks so much! I'd like to find a definitive part number for the U-Joint for the 5.9.
post #5 of 11 Old 11-15-2013, 02:14 PM Thread Starter
5point9Limited
Btt
post #6 of 11 Old 11-15-2013, 02:30 PM
zacko-zj
U joints are a higher frequency vibration than a wheel vibration since your driveline is turning a lot faster than your wheels. That can help diagnose where it is coming from.
zacko-zj is offline
post #7 of 11 Old 11-15-2013, 02:31 PM
zacko-zj
And why do you need a part number? That's what the parts guy is for
zacko-zj is offline
post #8 of 11 Old 11-15-2013, 02:33 PM
RWC
Originally Posted by 5point9Limited View Post
Btt
Did you go wiggle the u-joint with the Jeep in neutral? Based on the fact that you just bumped it without a report, my guess is not. You need to help us to be able to help you.
RWC is offline
post #9 of 11 Old 11-15-2013, 03:07 PM
zacko-zj
If in doubt change the u joints. They aren't that expensive
zacko-zj is offline
post #10 of 11 Old 11-16-2013, 02:19 PM Thread Starter
5point9Limited
Well, I did the neutral test and it looked real sloppy. Dropped the DS and the thing just fell apart. I think I found my problem. THanks again, boys.
Zacko-ZJ I want part numbers because they are not correct in any of the systems because the 5.9 has a heavy duty DS. I want the correct one. Thanks for your helpful comment.
post #11 of 11 Old 11-20-2013, 10:11 AM
speedbucket
looks like a regular 1310 ujoint went in where the niner takes the larger (1330 iirc) u joint
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
