| Rough Country TJ Belly Pan Skidplate Giveaway - NEW PRODUCT RELEASE |
| Best place to buy Rubicon Express! Don't Fear the Jeeper! | Insane Rough Country Deals Call for more Info!!! so insan | Barnes 4WD Universal 4 Link Kit |
| Jeep Registry | Register | Blogs | FAQ | Mark Forums Read | Search Members |
LinkBack | Thread Tools |
#1 | ||
Bad torque converter or transfer case?
1998 Bright Platinum 5.9, 242 swap, minor bolt-on goodies and 3" exhaust w/Super 40, SCT Tuner, 4" hybrid lift, 31" MTZ's 1998 Laredo 4.0 stock 1998 Ram 1500 |
#2 |
Definitely doesn't sound like the TQ Conv, I don't know where you got that from. The only thing that sounds like the tcase is bad is that it wouldn't shift out of lo.
Sounds like trans is slipping. When was the last time it was serviced?
A little ingenuity goes a long way. 1993 ZJ Limited 4.0 170k 249(no binding yet) GO DUCKS! |
#3 |
Tranny was shifting perfect till that day, then started slipping TONS all of a sudden. Fluid & filter in the tranny were changed about 5k ago and it never had any metal particles or discolouration.
Torque Converter symptoms I thought were; hwy vibration under light acceleration (torque shudder), whirring sound when pulling away, slipping as if in neutral. You don't think a seized torque converter could prevent the transfer case from coming back out of 4lo? Transmission seemed to operate just fine other than the hwy vibration a few days prior to the day is started slipping. It only took 10mins from the time it started making the loud whirring/gear noise til the slippage started and immediately became a problem. My Viscous Coupling is/was worn so maybe it finally died on me? Thx for any input again.
#4 |
I don't think a seized converter would cause the tcase not to shift. They are part of completely different systems.
And a seized converter wouldn't even allow the jeep to move, I would think. The vibes may be the TqConv Clutch.....
#5 |
Okay, I meant Torque Converter related, so pump/solenoid/TCC I guess.
Also, fluid is still nice and red with no burnt smell or foaming.
#6 |
![]() Join Date: Feb 2006
Try the stall test.
Jeff 6" Hybrid RE SF - 33"x12.50" GY Duratracs - Built 46RH W/ Red Eagle Clutches & Powerpack, Kolene Steels,Superior Shift Kit - Hughes 15LXTM TC - Tranz Temp Gauge - Military OP Gauge - JKS Adj Rear TB - IRO HD TBB W/Custom TB - FortCollinsZJ Steering Box Brace - RE Monotubes - Gen II Discos - Homebrew Rock Rails - 1 Ton OTK Steering - 242 Swap - SS Brake Lines - F&R Poly Greaseable Swaybar Bushings - Clear Corners W/ Euro Turns - GTP Louvers - K&N FIPK II - Magnaflow HFC - CB PRO Muffler - Yadda Lifted 94 5.2 ZJ Bone Stock 94 5.2 ZJ Limited Tow & Pimp Daddy Gold W/LSD |
#7 |
It will barely go in gear right now, unfortunately, or else it slips too much to create much of a load to come close to doing a stall test.
#8 |
Check the transmission fluid again to see if it's black or burnt.
Want to swap an NP242 or NP231 into your ZJ? Here's how: http://www.jeepforum.com/forum/f13/np249-np231-np242-swap-information-updated-685644/ |
#9 |
Don't forget to check it warm and in neutral.
#10 |
I'll check again, last time I checked was when it first started slipping, then limped it home so maybe it's changed colour.
Thx!
#11 |
Okay, so I checked the fluid today and it's nice and red still, looks normal. Doesn't smell burnt either, no foaming/bubbles, so that's a good sign.
I can get it to go in gear now, but the transfer case is still in Lo and the Lo light on the VIC stays on too when shifting the TC. When put in reverse, there's a whining or high pitched grinding sound and it takes a few seconds to slowly engage that gear, doesn't seem to transfer the power easily as it takes more than necessary throttle input to get the vehicle to move. When put in drive it engages slowly without any whining/grinding sounds and again it takes more throttle than necessary to move but it does move! I thought it was pooched but I think the transfer case was partly in neutral before. Any ideas? Could the whining sound when put in reverse be the torque converter?
#12 |
bumpity bump 10chars
#13 |
is it worth it to try swapping transfer cases? still slips like crazy in gear but the tranny fluid seems okay. Could anything in the transfer case cause these symptoms?
#14 |
If the TC was slipping you would hear a loud popping noise. Sounds like your tranny needs a rebuild with a new torque converter. You could try manually selecting the TC into 4FT though just to make sure. 9/16" wrench ...
#15 | |
I swapped the 44re out of my 96 parts jeep for now, and took the opportunity to put in the 242 I've had ready for some time. Still suspect the torque converter was the culprit though, there was fluid leaking in the bellhousing, but will not know for sure till I bring the 46re into a tranny shop for diagnosis. Thx for all the advice guys, I swapped the tranny and transfer case myself and it was much easier than anticipated. Tranny jack is a must when doing this by yourself, lol, only cost $20 to rent for half a day too.
| Thread Tools | |
| Thread | Thread Starter | Jeep Forums | Replies | Last Post |
| 247 transfer case bolt torque question | mattman0o0o | ZJ & WJ Technical Forum | 0 | 03-08-2009 05:23 PM |
| Torque Converter ? | JEEPOLD | ZJ & WJ Technical Forum | 2 | 12-12-2008 04:16 PM |
| Torque Converter | rkoz1 | WK & XK Technical Forum | 1 | 04-30-2008 06:24 PM |
| torque converter ??... | bsd083 | ZJ & WJ Technical Forum | 2 | 04-13-2006 12:20 AM |
| what is a torque converter? | pygocentrus | ZJ & WJ Technical Forum | 5 | 09-07-2003 08:09 PM |
Jeep, Wrangler, Cherokee, Grand Cherokee, and other models are copyrighted and trademarked to Jeep/Chrysler Corporation. JeepForum.com is not in any way associated with Jeep or the Chrysler Corp. |
