Bad Thermostat - JeepForum.com
post #1 of 5 Old 11-18-2013, 09:39 PM Thread Starter
NoliftZJ
Bad Thermostat
So I had a gasket leak at the thermostat so I might as well replace the thermostat while replacing the gasket. My thermostat was stuck open! I'm not sure what the repercussions could be, but I'm flushing the system and installing a new thermostat. Here's a pic:
NoliftZJ is offline
post #2 of 5 Old 11-18-2013, 10:02 PM
JasonStebbins
I went with the Stant Superstat and it works great all year round. Nothing wrong with flushing the system. A stuck open thermostat will yield lukewarm heat through the vents and may cause overheating.
195 degree thermostat is OEM.
Poop
JasonStebbins is offline
post #3 of 5 Old 11-18-2013, 10:10 PM Thread Starter
NoliftZJ
I replaced with a Murray Temperature Control Ultra - Ultrastat Thermostat 195 degree. Thanks for the input.
NoliftZJ is offline
post #4 of 5 Old 11-19-2013, 12:14 AM
jnicewan
That's one of those "fail-safe" thermostats. It is stuck open but that brass colored clip is whats holding it open. Those are purposely made to hold the thermostat open in the event of a failure/overheat. Now that I think about it I have never removed one of those that was not in the fail-safe failure position, they seem to "fail" a lot. I would get a regular OEM stat to replace it.
With a good operating thermostat you should notice better fuel economy since the engine will run at operating temps. You should also have a better working and hotter heater.
jnicewan is offline
post #5 of 5 Old 11-19-2013, 08:05 AM Thread Starter
NoliftZJ
Sounds good! Thanks!
NoliftZJ is offline
