Bad squeaking from the front end when ZJ is cold. Any thoughts? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Bad squeaking from the front end when ZJ is cold. Any thoughts?
Amsteel Blue Synthetic Winch line Free ShippingRing & Pinion's, Lockers, 4340 Axles, Install Kits, BaRaceline/Allied Wheels on Sale NOW !
Unread 12-06-2008, 07:23 PM   #1
squashman702
Mongo-fabbed
squashman702's Avatar
1994 ZJ
I've noticed a bunch of extra noise out of the front of my ZJ when it's been cold the past couple of weeks. It's especially apparent when the temperature is around freezing or has been. I checked my tranny and transfer case fluids, and all is well, except for a slight leak between the two. The noise seems to be coming from the front end. What could be going bad/is wrong?
Think Twice Garage
"I guess I'd just run it?"
squashman702 is offline   Reply With Quote
Unread 12-06-2008, 07:32 PM   #2
NorCrossZJ95
Hello, im not sure if this will solve your problem, but sometimes when i start up my zj there is a loud and annoying speak that comes fron the front end(engine). I found it was because i got mud in my distributor cap, so i just squirt some wd40 in there and it goes away. I have to do this occasionally, maybe thats a clue?? anyway hope this helps in any way
NorCrossZJ95 is offline   Reply With Quote
Unread 12-06-2008, 07:55 PM   #3
my96grand
Ive been getting new cold morning squeaks rattles and some groans in the am before work too.been around 20 here when I go to work.once she's warm,she works herself out.just chalking it up to the cold for now.no real problems yet.
new here,hello everyone. 96 zj,4.0. skyjackers,flow 40 series,2.5 tailpipe,hiflow cat.memphis amps,10 memphis sub,mb quarts all around.acell cap,rotor wires and coil.
my96grand is offline   Reply With Quote
Unread 12-06-2008, 08:20 PM   #4
squashman702
Mongo-fabbed
1994 ZJ
Could it be wheel bearings or something along that line?
Think Twice Garage
Unread 12-06-2008, 08:40 PM   #5
elmer_fud
is it the belt?
I know that is one of the things that squeaks on our truck when it is cold
Brian
95 ZJ, 5.2 V8,160,000 miles
Colorado Jeep Club member Pi
Originally Posted by Speedycat View Post
I am not one to be changing lanes at 70 mph on a lifted truck on 33's, but since I am in Miami, I have to be prepared for the continuous influx of new drivers whose previous ride was a bicycle with wooden wheels.
Originally Posted by FPKites View Post
badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, Mushroom!!! :D
Originally Posted by ZeeJay1997 View Post
Or just tie a 12 lb fish to a one foot pipe.
elmer_fud is offline   Reply With Quote
Unread 12-06-2008, 09:09 PM   #6
squashman702
Mongo-fabbed
1994 ZJ
Originally Posted by elmer_fud View Post
is it the belt?
Definitely not the belt, that only squeaks when the defroster is on.
Think Twice Garage
Unread 12-07-2008, 10:03 AM   #7
squashman702
Mongo-fabbed
1994 ZJ
To the top
Think Twice Garage
Unread 12-07-2008, 11:02 AM   #8
elmer_fud
can you try and isolate which part of the engine the noise is coming from. It may be bearings or something along that lines.
Brian
Unread 12-07-2008, 12:14 PM   #9
squashman702
Mongo-fabbed
1994 ZJ
It really doesn't sound like the engine. The noise is dependent on speed, not on RPM. Sounds mostly like it's coming from the front axle.
Think Twice Garage
Unread 12-07-2008, 12:35 PM   #10
WhiteOut
WhiteOut's Avatar
The sound is coming form the right hand side of the front axle right/ I have the same issue and Im getting it checked out on Tuesday when Im at the shop.
WhiteOut is offline   Reply With Quote
Unread 12-07-2008, 12:54 PM   #11
Ubergrob
we might have the same problem...
Does it almost sound like an uneven squeak? like a dj swivelling a record or something? The sounds like it is coming from the interior of the car, up on the dashboard.. it sounds like it comes out of the AC.
it only does it when i accelerate.
Ubergrob is offline   Reply With Quote
Unread 12-07-2008, 03:07 PM   #12
squashman702
Mongo-fabbed
1994 ZJ
Definitely let me know what you find out.
Think Twice Garage
Unread 12-26-2008, 08:58 AM   #13
Srhmn8r
Any resolution to this? My TJ has a sqeak from the front end of the jeep on cold mornings, sounds like it's coming from the front right axle. It's rotational, so the faster I go, the faster it squeaks. The sound resembles a belt squeak, but I'm almost certain it's not a belt, since the squeak is related to spead, and not RPM. It usually goes away after about 2-3 minutes and there's no more ill effects after that.
03 Rubicon RE 3.5" and 1.25" JKS BL 285/75/16 Kumho MT's
Srhmn8r is offline   Reply With Quote
Unread 12-26-2008, 10:45 AM   #14
Eldoradoman
Check, lube, or replace your sway bar bushings.
1998 Bright Platinum 5.9, 242 swap, go-fast goodies ,and 3" exhaust w/Super 40, SCT Tuner, 4" hybrid lift, 33" Claw TTC Radials
Eldoradoman is offline   Reply With Quote
Unread 12-27-2008, 06:39 AM   #15
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
I agree with the lubing of the swaybar bushings.
Hunter
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
http://www.kevinsoffroad.com/
602.841.3355
For your performance needs:
kolak@kolakperformance.com
480.998.3661
Texas ZJ1 is offline   Reply With Quote
