Bad Smell - JeepForum.com
post #1 of 7 Old 11-25-2004, 01:40 PM Thread Starter
wreck76
wreck76's Avatar
Bad Smell
2002 WJ, whenever i use the A/C or in the cooloer times the windshield defroster, i get a musty damp kinda smell. this is only when i use these two settings. ideas?
wreck
-I am a man. And I can change. If I have too. I guess.-
Red Green
Canadian Jeep Club Member#17
wreck76 is offline
post #2 of 7 Old 11-25-2004, 01:58 PM
defffrek
Try pouring some watered down lysol(or something along those lines) into the fresh air intake right in front of the windsheild while you have the a/c,fan or watever you choose. it should kill some of the musty and mold in there.
Or indirectly spray some air sanitizer stuff below the dash where the recirculating air intake is, while you have the blower on recirculate.
To prevent the mold/musty smell, i try to turn off my a/c, defrost,fan about 5 mins before i get home, so that it has enough time to clear the moisture out of the system. B/c the mositure staying inthere is causing the bad smell
95 xj 2dr
Herculined, 4.5" Rustys, 33" Procomps, Frnt/Rear bumpers winched, 400 watts of lighting
defffrek is offline
post #3 of 7 Old 11-25-2004, 02:22 PM
dirty tools
edited for deletion
dirty tools is offline
post #4 of 7 Old 11-25-2004, 05:11 PM
mr_user
Good idea..Your referring to the blower motor underneath the passanger dash i suppose? Is there a certain place to drill that would be more beneficial?
Old: '96 ZJ 4.0, 32" MT/R's, 4.5" Lift, Mickey Thompsons, JKS Disco's
New: '02 WJ Limited 4.7L, Stock for now
mr_user is offline
post #5 of 7 Old 11-25-2004, 06:34 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Matt,
you guys are talking different models so be very specific so you don't get the hole in the wrong place.
I just spray the interior with febreeze and then run the recirc on the A/c, no more bad smells.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #6 of 7 Old 11-25-2004, 07:06 PM
dirty tools
edited for deletion
post #7 of 7 Old 11-26-2004, 04:37 PM
Meerkat
Wreck,
Do you have the filter in your air intake?
If you remove the plastic grill underneath the wipers, you can look down inside to tell. I know there is a filter available for your year Jeep, though not all of them have the filter installed.
If you do, it may have gotten wet and mildewed... just my
Warren
Black 1996 5.2L ZJ Limited
Meerkat is offline
CRD Bad Smell fred99x WK Grand Cherokee & XK Commander Forum 76 09-17-2012 11:16 AM
Really odd smell KABADB WK Grand Cherokee & XK Commander Forum 14 09-21-2009 12:22 PM
A/C Smell Larrysjgc ZJ Grand Cherokee Forum 0 04-28-2009 04:20 AM
Gas Smell!! JeepRagan ZJ Grand Cherokee Forum 6 10-03-2007 05:29 PM
Oil Smell wlmuncy ZJ Grand Cherokee Forum 8 12-19-2005 04:18 PM
