Bad Seals - JeepForum.com
post #1 of 3 Old 07-25-2011, 10:49 AM Thread Starter
jeepmanzj1955
Bad Seals
I have a 96 GC Laredo that seems to have an issue with the rear axel seals leaking. I changed them and the bearings about a year ago and the right
side is starting to leak again. ?
jeepmanzj1955 is offline
post #2 of 3 Old 07-25-2011, 03:45 PM
97zjdriver
the vent on top of the axle is probly cloged. i used a small drill bit and drilled it out on the rear of mine. there is probly build up in the line or the nipple on the axle.
97zjdriver is offline
post #3 of 3 Old 07-25-2011, 04:36 PM
gomes512
1994 ZJ
If the above tip doesn't work then I'd pull the shafts again and check for any abnormal wear where the seal rides. Any pits greatly reduce the seal service life.
gomes512 is offline
what other seals to replace frenchface ZJ Grand Cherokee Forum 5 02-15-2011 11:54 PM
TC seals cp1109 ZJ Grand Cherokee Forum 0 06-29-2010 05:54 PM
Leaking seals? kellster WK Grand Cherokee & XK Commander Forum 9 02-13-2008 08:05 PM
D44a Seals.. Ds4x4 ZJ Grand Cherokee Forum 8 05-07-2007 11:12 AM
oil seals compugeek ZJ Grand Cherokee Forum 13 03-15-2006 10:41 AM
