bad pull, please help - JeepForum.com
post #1 of 15 Old 09-19-2009, 04:52 PM Thread Starter
g-off70
the jeep has been pulling bad to the right, and i cant think what is wrong. the tires are about 2 months old with about 3000 miles on them. the aligment is perfect, just had it checked. cant think what could be wrong. any help is greatly appreciated
by the way, it is all stock
g-off70 is offline
post #2 of 15 Old 09-19-2009, 04:53 PM
Jones
Consider the following...
Jones's Avatar
Does it pull all the time or just when braking?
Jones is offline
post #3 of 15 Old 09-19-2009, 04:55 PM Thread Starter
g-off70
all the time
g-off70 is offline
post #4 of 15 Old 09-20-2009, 07:10 AM
michiganmaveric
Got Beer?
michiganmaveric's Avatar
2011 JK Wrangler
Check the tire pressure. I had a pulling problem that was related to the pressure being lower on one side. Try rotating your tires and see if the problem goes away, if it does it is tire related.
Previous Jeeps: 84 CJ7 (A True Jeep), 2000 XJ (163,000 Miles/Totaled (Pictures of wrecked Jeep in gallery)), 2004 WJ (parting out die to major electrical issues)
If you don't have time to do it right the first time, how do you have time to do it over.
Lifetime member #13
lifetime member/airforce26yrs
2011 Tango/Mango JKU
michiganmaveric is offline
post #5 of 15 Old 09-20-2009, 08:41 AM
gatorayde
It could also be the teves calipers going bad and the passenger side is dragging.
gatorayde is offline
post #6 of 15 Old 09-20-2009, 09:44 AM
michiganmaveric
Got Beer?
2011 JK Wrangler
Possible, but he should have a brake burning smell after driving for awhile.
Lifetime member #13
post #7 of 15 Old 09-20-2009, 02:40 PM Thread Starter
g-off70
i do have a buring every now and then. i will look at it, and im going tuesday to get my tires rotated and balanced. hope it does the trick
g-off70 is offline
post #8 of 15 Old 09-22-2009, 03:28 AM
jeepheller98
dought that will work
98 ZJ 3" lift homemade snorkel. JKS quicker disco 5.2L 150,000, 31x10.5 pro comp muds
jeepheller98 is offline
post #9 of 15 Old 09-22-2009, 07:34 AM Thread Starter
g-off70
why do you dought it will work?
g-off70 is offline
post #10 of 15 Old 10-01-2009, 08:34 PM Thread Starter
g-off70
ok, i got the tires rotated and balanced, and the alignment checked. it still has a pull to the right, and the brakes are fine. any more ideas?
g-off70 is offline
post #11 of 15 Old 10-01-2009, 08:36 PM
gatorayde
Maybe your springs are sagging badly and your tires aren't center under the axle anymore (something like -1" of lift)
post #12 of 15 Old 10-01-2009, 08:47 PM
indept
They SHOULD have checked the front end for bad parts when they checked the alignment but then they don't always do what they should. Check for bad tie rod ends. Jack up 1 side at a time & grab the tires at 9 & 3 o'clock (or you can do it after dinner ) and try turning the tire left then right fairly quickly but with some force. It should be tight so if you hear a clunk have someone look under to see what has the play (it's tough to do both yourself).
2000 WJ 4.0L 42RE 242 TC
190,091 miles & counting
indept is offline
post #13 of 15 Old 10-01-2009, 09:03 PM Thread Starter
g-off70
i was thinking that, but wasnt for sure. actually have time to check tomorrow.
g-off70 is offline
post #14 of 15 Old 10-01-2009, 09:04 PM
RMFK13
mien did this, but it was my caliper... but it was a bad brake smell along with it.
19 and startin to learn.
RMFK13 is offline
post #15 of 15 Old 10-01-2009, 09:26 PM
WiCkeDuDe
WiCkeDuDe's Avatar
Could also be the incorrect camber from a bad balljoint. If im not mistaken didnt the factory come out with a adjustable ball joint to help in cases like this?
I Have WJ Stuff for Sale
WiCkeDuDe is offline
Im Going to a You Pull IT JY ntaousakis ZJ Grand Cherokee Forum 1 05-15-2009 08:26 AM
how does the 05 wk pull littleleonard WK Grand Cherokee & XK Commander Forum 7 05-04-2009 02:55 PM
U Pull and Save? Slamm36 ZJ Grand Cherokee Forum 15 12-24-2006 07:03 PM
h2 pull Derek33 ZJ Grand Cherokee Forum 50 02-10-2006 10:59 AM
WJ with a pull to the right - HELP scottjclaypool ZJ Grand Cherokee Forum 3 06-27-2004 12:41 AM
