bad pinion bearing question - JeepForum.com
post #1 of 8 Old 05-08-2010, 08:06 PM Thread Starter
EBT531
I'm pretty confident my front pinion bearing is going. I can hear a whine from the front on de-acceleration between 50-40mph. Right now you have to have the window down to hear it, so my question is how long typically before it totally goes? (1000 miles? 2,3,4?)
Do these things get louder as it gets worse?
When its really bad will the whine be at all speeds vs just the 10mph stretch I have now?
Anyone pay a shop to replace the bearings? I'm curious how bad the bill is going to be.
EBT531 is offline
post #2 of 8 Old 05-08-2010, 11:38 PM
CULate
1930 J-Series Truck
I haven't tore into a D44A but plenty of regular D44s. The front bearing will come out after removing the seal. The back bearing is pressed on & requires removing the ring & pinion.
CULate is offline
post #3 of 8 Old 05-09-2010, 01:14 AM
nitecop
I think he is talking about the front axle (D30) not the back.
To the OP, are you sure its not a wheel bearing?? You might want to check that before the teardown.
Jim
USW, OAPSE Union member
99 TJ Sahara 4.0 5-Sp FUV + farm worker
Project f-Xj F150/XJ Ford eXtreme jeep combo
06 6 Speed LJ my daily driver.
Colorado Jeep club memeber #505
nitecop is offline
post #4 of 8 Old 05-09-2010, 09:26 AM Thread Starter
EBT531
Possible, would a wheel bearing only be during de-acceleration?? I just replaced the rear wheel bearings yesterday and they were shot. Right side was bad enough I had to replace the axle shaft as well (worn/pitted)
EBT531 is offline
post #5 of 8 Old 05-09-2010, 09:30 AM
nitecop
when they are just starting to wear there won't be much noise. as they get worse of course the noise will get worse.
As far as a shop, if it is a pinion bearings most shops won't change just one. besides if you go to change 2 bearings the labor is the same if you changes carrier bearings as well.
Jim
nitecop is offline
post #6 of 8 Old 05-09-2010, 09:53 AM Thread Starter
EBT531
So how many hours shop labor is average? Its been awhile but we used to pay $300 an axle to change gears (with the cost of gears) so I figure the labor is about the same right?
EBT531 is offline
post #7 of 8 Old 05-09-2010, 10:05 AM
nitecop
If you didn't have to swap gears(and the possibility of required reshiming ) I'd just do it myself. you'll just need to toqure the bolt to the correct amount.
shop prices vary. I've seen as low as $200 and as high as $450 for a bearing change.
Jim
nitecop is offline
post #8 of 8 Old 05-09-2010, 10:06 AM Thread Starter
EBT531
Thanks! I'll shop around
EBT531 is offline
Sign of a Bad Wheel Bearing or Ring and Pinion Bearing? torchd ZJ Grand Cherokee Forum 28 02-15-2014 09:14 AM
Pinion bearing? sdog30 ZJ Grand Cherokee Forum 10 08-10-2011 01:38 PM
Bad pinion bearing 98ZJDan ZJ Grand Cherokee Forum 4 04-01-2010 03:26 PM
d44a pinion bearing question gatorayde WJ Grand Cherokee Forum 1 03-12-2010 03:21 PM
Pinion Bearing question and Rear Main neoncrazy101 ZJ Grand Cherokee Forum 2 10-22-2009 08:59 AM
