bad oil leak - JeepForum.com
post #1 of 3 Old 03-03-2013, 02:27 PM Thread Starter
jiveturkey69200
bad oil leak
I have an oil leak that runs down the passenger side of the bell housing and runs off the bottom of the bell housing. Of course you can't see anything on a V8. I changed the valve cover gasket on the passenger side. Its still pouring out. I'm hoping its the oil pressure sending unit. Anything else I should check? I'm hoping its not the intake. Does the distributor have to come out to change intake gaskets?
Dan
95 Jeep Grand Cherokee, 318, AT, NP 242, 31's
jiveturkey69200 is offline
post #2 of 3 Old 03-03-2013, 04:28 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
usually the sending unit.
distributor does not come out for intake work.
ratmonkey is offline
post #3 of 3 Old 03-03-2013, 08:12 PM Thread Starter
jiveturkey69200
Thanks for the info. My sending unit pretty much fell apart as soon as I touched it. What a pain in the rearend these are to change!
Dan
