Bad Idle rough take off. Bad o2 Harness? - JeepForum.com
post #1 of 8 Old 02-26-2007, 05:41 PM Thread Starter
SAZJ
Ok so I was having a problem with my o2 sensors. Its reading a hot o2 sensor even when the engine is turned off. leads to either an ECU problem or a Wiring harness. Anyways I have had this problem for about 4 months, and it was running fine. But I disconnected the battery and then it was no longer reading the code, until I did a full throttle acceleration at which point the o2 warning came back on. Also when i disco the battery and then reconnected it the jeep started idling really rough when in gear, and then any tap on the gas at all and it will jump really hard and then sputter. Any Ideas on what I should check out? its got 2 new o2 sensors so I know thats not the problem.
SAZJ is offline
post #2 of 8 Old 02-26-2007, 06:03 PM
FPKites
ZJjazzyJim
FPKites's Avatar
Check the wires coming from the harness to see if they're nicked. The ECU is not real-time, so it'll store your hot O2 sensor code. I would suspect you could see the issue pretty close to the sensor if the harness is messed up.
Jim Karlin
"Duh! Big RED Jeep!!!"
or
96 ZJ Laredo
5" lift, Claytons, KOR radiator support, rear bumper, steering brace, etc, etc, etc.
04 WJ Overland
Clean.... :D
FPKites is offline
post #3 of 8 Old 02-26-2007, 06:07 PM
greasefingers
greasefingers's Avatar
1994 ZJ
You need to explain the issue better. What does it mean that the sensor reads hot? Do you mean that the heating element in it is on when the engine is off? What codes were thrown? What engine do you have? Is it only for the upstream 2 sensors?
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #4 of 8 Old 02-26-2007, 06:13 PM Thread Starter
SAZJ
The guy who pulled the code said it was sensor 1 bank 1, that it was "Hot" even when the engine was off, I assume he means that the sensor is in error. But he did say I should be extremely worried about it, so maybe he ment that it actually was temp. hot. Its a 5.2l I believe that its code on the machine was something like p2039 But he didn't let me look at it
SAZJ is offline
post #5 of 8 Old 02-26-2007, 06:30 PM
rxl
rxl's Avatar
I'm pretty sure he's refering to a cylinder. If Steve pops in again , he may be able to tell you which side is bank one and which cylinder is #1. Check the coil. I had a bank 1 #2. The coil was cracked so the cylinder would'nt fire. The computer then cut off fuel to the cylinder making the engine seem to run smooth again but lacking a bit of power. Anyway, the code came up with a lean #2 cylinder. This is a newer Winstar limited but same idea, Just a little more software. Like cutting off the fuel to the cylinder to stop the cat. from melting down.
I bought "MY JEEP" for my wife
I bought "MY OTHER JEEP" for my daughter [she sold it]
I finally bought one for me
Canadian Jeep Club Member #7
99 GC limited
4.7 Quadradrive
97 TJ Sport
4.0 5 speed
99TJ Sahara
4.0 Auto
Sold to a life of blacktop
94 ZJ Limited
I6 Quadratrac
rxl is offline
post #6 of 8 Old 02-26-2007, 07:00 PM Thread Starter
SAZJ
Its bank 1 Sensor 1 He is referring to the first o2 sensor not cylinder. But I do appreciate your input. All 8 Cylinders are firing correctly, its just idling a little rough like its running lean. The code was improper voltage o2 sensor Bank 1 Sensor 1
SAZJ is offline
post #7 of 8 Old 02-26-2007, 07:14 PM
greasefingers
1994 ZJ
Thatís the driverís side upstream sensor. I still donít get what is meant by hot. Temperature hot or that it has juice. I assume that it is temperature hot Ö but of course it will be for awhile so that really doe not make much sense either
Cheers Steve
post #8 of 8 Old 02-26-2007, 07:16 PM
greasefingers
1994 ZJ
Yep that means the sensor is NFG. Only use Mopar sensors. Most aftermarket ones do not work well (especially Bosch)
Cheers Steve
242 Has a Rough Idle. Some_Anchovies ZJ Grand Cherokee Forum 30 10-04-2009 09:39 AM
02 Gc With Rough Idle, 4.0 Rough... evanlaczi ZJ Grand Cherokee Forum 4 05-09-2009 03:53 PM
4.7 rough idle sledneck700 ZJ Grand Cherokee Forum 18 12-26-2007 05:17 PM
Rough Idle/High Idle/Weird Shifting FIXED!! UKFan4Sure! ZJ Grand Cherokee Forum 5 04-28-2007 07:43 AM
95 ZJ Rough idle knl ZJ Grand Cherokee Forum 20 02-11-2007 06:38 AM
