bad horn? - JeepForum.com
post #1 of 44 Old 06-17-2012, 07:05 PM Thread Starter
liftedzj1994
1994 ZJ
bad horn?
hey. trying to get my jeep inspected within the next week or two.. with my horn i click the button and it just makes a clicking noise. what could be wrong with it?
also quick question. my airbag light is on, is there like something common with 94 zj's that make the airbag light come on orr?
liftedzj1994 is offline
post #2 of 44 Old 06-17-2012, 07:13 PM
andygio71
Don't know about the bag, but that clicking sound is likely the relay working correctly. Either your horn (horns?) is/are shot, or the wiring leading from the relay is. Just my guess from what I've read on the forums
andygio71 is offline
post #3 of 44 Old 06-17-2012, 07:14 PM
JasonStebbins
Sounds like the horn itself is bad. It is located under the passenger side of the bumper cover. The clicking you here is the fuse/relay working.
You're supposed to get your airbag inspected every ten years at the dealership. I'm almost positive it's free.
JasonStebbins is offline
post #4 of 44 Old 06-17-2012, 07:23 PM Thread Starter
liftedzj1994
1994 ZJ
if i bring it to class chrylser /dodge dealership they should check my airbag why its on for free? and so i should check the wiring and if i dont see anything obvious, get a cheap horn and hope thats the problem
post #5 of 44 Old 06-17-2012, 07:26 PM
JasonStebbins
Yes sir. It's not something that is supposed to be done by a local mechanic. Won't hurt to give them a call and verify.
Swap in a new horn from a junkyard ZJ, it's only two bolts if I remember correctly.
post #6 of 44 Old 06-17-2012, 09:13 PM Thread Starter
liftedzj1994
1994 ZJ
do you know if the horns/&horn circuit are different between the 4.0 and 5.2 grand cherokees?
post #7 of 44 Old 06-17-2012, 09:26 PM
KoreaZJ
1994 ZJ
Before replacing the horns.... Push the horn button and make sure you have 12v at the horns... make sure the ground is good.
There's an impact sensor behind each front bumper corner. Make sure the connectors are seated properly. My 94 came from the factory with one connector only partially plugged in. A few years later it came loose and the airbag light came on.
KoreaZJ is offline
post #8 of 44 Old 06-17-2012, 09:29 PM Thread Starter
liftedzj1994
1994 ZJ
when i push the horn button it clicks pretty loud from behind the glove box
post #9 of 44 Old 06-17-2012, 10:07 PM
KoreaZJ
1994 ZJ
Clicking sound is the normal horn relay sound located below a panel in the bottom of the glove box. Just because the relay clicks properly, it could still be bad. And even if the relay is working, doesn't mean the 12v is making it to the horns up front.
You can swap the relay with another one to test it... and also check for 12v and ground at the horns.
KoreaZJ is offline
post #10 of 44 Old 06-18-2012, 11:33 AM
kawasaki3070
My jeep was doing the same thing, then one day it just randomly came back on. I'm sure it's partially plugged in, i'll look at it one of these days
kawasaki3070 is offline
post #11 of 44 Old 06-18-2012, 12:20 PM
hdrocknroll
The horns are known to go poop, mine did, JY horns work great.
Could be your connections too
Always !! Keep A Firm Grip On Your Tool !!
Watch Out For The Air Hose Gone Wild!! Or Wear A Cup,: True Story
Originally Posted by rooster51 View Post
Whats the worse that can happen? Your jeeps already broke.
hdrocknroll is offline
post #12 of 44 Old 06-18-2012, 12:32 PM
PolkaPower
You can put in a much louder horn. They come in handy
PolkaPower is online now
post #13 of 44 Old 06-18-2012, 01:35 PM
hdrocknroll
I was thinking on doing that, and wish I had, I may still do it.
Train horns are a little extreme though.
I would like to find a reasonably priced one , that's LOUD
I was at the JY anyway so grabbed some for 5 bucks
post #14 of 44 Old 06-20-2012, 12:44 PM Thread Starter
liftedzj1994
1994 ZJ
i was just looking under there &cant find anythingg. can someone tell me where about these sensors are???
post #15 of 44 Old 06-20-2012, 01:13 PM
Proph2010
1994 ZJ
What sensors? The airbag sensors? Theyre only relevant because the airbag sensors and the horn wires and bundled together to the front right of the jeep, it's literally directly under your passenger headlights behind the plastic bumper.
If you are in fact looking for the airbag sensors, there are two of them(one on each side) of you actual bumper underneath your plastic bumper.
Proph2010 is offline
Horn doesn't work when pressing steering wheel; horn does chirp when arming/panic cmassey_2006 WK Grand Cherokee & XK Commander Forum 10 07-31-2017 11:00 PM
Horn sounds like a Toyota Prius horn... cherokeen ZJ Grand Cherokee Forum 8 08-01-2011 09:12 AM
Horn that just goes off... jporlier WK Grand Cherokee & XK Commander Forum 7 09-16-2008 08:05 PM
Horn YKZ_Pilot ZJ Grand Cherokee Forum 6 03-20-2006 05:11 PM
95 ZJ - WHERE is the horn or horn wiring n4aof ZJ Grand Cherokee Forum 2 09-06-2005 07:57 AM
