Bad fuel gauge or sending unit - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Bad fuel gauge or sending unit
8.8 Swap Kit w/ TRUSS for JeepsROCK BOTTOM prices on LIFT KITS at Rockridge4wd!! WANT TO Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 03-15-2015, 03:44 PM   #1
Jtsullivan85
So I filled up drove for a wile and the gauge wasn't dropping then it started to drop to 3/4 at what seemed to me a normal rate. I filled up and it took 7 gallons to fill from 3/4 to full. It also took about 5 minutes for the gauge to read full after filling. Now is this a sending unit problem or a guage? I have a 100 mile drive round trip to work and woollike to not run out of gas on the road
Jtsullivan85 is offline   Reply With Quote Quick reply to this message
Unread 03-16-2015, 11:33 AM   #2
Oldfrog
There was a recall on that 97 sending unit. Drop by a dealer and let them put your VIN# in the system to see if it was done. If not.....you get a freebie...labor and all.
Cajun Recipes and Fishing tips
On my seventh PCM. Might have finally gotten a good one this time. Crossing my fingers.
Stalling? Work through Zeejay's list
Oldfrog is offline   Reply With Quote Quick reply to this message
Unread 03-16-2015, 12:05 PM   #3
RedRiverT
If you filled it up all the way up into the fill hose until it won't take any more, i.e., "topped it off" like so many of us do, there will be gas above the float that has to get used before it will start to drop. 7 gallons until it reads 3/4 sounds OK, I think. I've refilled mine at 3/4 once and I think it was 6-something. I've got out of the habit of topping it off after I soaked my shoes in gas a couple of times. I usually go up to the next round 5 or 10 cents after it shuts off the first time, but mine still doesn't move off of Full for a little while. My gauge is slow to go up too, but it doesn't take it 5 minutes. Maybe a minute.
I've drained the tank 3 times in the past 4 months from a little below 1/8 on the gauge and it had ~6-1/2 gallons in it. One time I drove 9 miles straight to the gas station after putting the 6-1/2 back in, on the county roads at 35 mph, and I put 18.6+ in it to top it off. Maybe the pump was cheating me.
RedRiverT is offline   Reply With Quote Quick reply to this message
Unread 03-16-2015, 09:59 PM   #4
Uniblurb
Uniblurb's Avatar
Good tip by Oldfrog! Rather than going to the dealer, type your VIN into the below form. It will immediately show what recall work has not been completed or is outstanding on your 97. Of course only the dealer or reputable shops which report this work completed is included.
You don't need to register or login when checking for this recall work.
http://www.moparownerconnect.com/oc...allsQuery.aspx
Link courtesy of a larger Jeep/Chrysler link supplied by member MrRoundel.
Now for the not so technical stuff. Next time you fill up and your gas gauge is super slow going up smack the bottom of the fuel tank with a 2x4 while then looking at the gauge quickly. Good chance it may go up pretty quick and really doubt if the gauge in the dash is bad. Good luck.
96 4.0 ZJ Laredo, 2004 4.7L WJ Limited, 93 4.0 XJ (spare), 96 4.0 XJ (son's)
-Stalling ZJ? 12 things to check before replacing a sensor; the Dirty Dozen
-Crankshaft position sensor multimeter test. & video of testing.
Uniblurb is offline   Reply With Quote Quick reply to this message
