Bad Front hub bearings OR ball joints? - JeepForum.com
post #1 of 8 Old 04-14-2008, 10:33 AM Thread Starter
jerry1847
1980 CJ5
Hi all,
I have play at 6 and 12 on my front tires, 3 and 9 is fine.
Is that the hub assy or ball joint?
From what i can tell its the hub assy but i want to be sure before i get to work.
jerry1847 is offline
post #2 of 8 Old 04-14-2008, 10:35 AM
nierace
nierace's Avatar
2003 WJ
I would go with hub assy. It's alot easier to do that first over BJ's too
Nickerdoodle
03 WJ 4.7 242HD Kolak/IRO 5" Clayton LA's
35" BFGoodrich KM2
North East Offroad Club
nierace is offline
post #3 of 8 Old 04-14-2008, 10:48 AM
ajmorell
ajmorell's Avatar
You might as well pull it apart and then go from there. My vote is actually for the ball joints...if they are bad you should be able to tell once you have everything stripped down to the knuckle.
ajmorell is offline
post #4 of 8 Old 04-14-2008, 10:49 AM
chrono4
I would say ball joints too, but it's hard to know until you get down into it.
chrono4 is offline
post #5 of 8 Old 04-14-2008, 11:06 AM
QuadraTokn
QuadraTokn's Avatar
1930 WJ
If there is play at 12 and 6 it sounds like a BJ or two are bad. But it could be the hub.
NEW Dana 44a Axle Truss and Skid !
WJ Grand Cherokee Tube Doors For Sale !
ZJ Grand Cherokee Tube Doors For Sale !
PARTS FOR SALE from 10 WJ Grand Cherokees ! !
QuadraTokn is offline
post #6 of 8 Old 04-14-2008, 12:57 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
hub is side to side, bj's are verticle for the wiggle test.
gonna have to say it's a balljoint or two.
stripping it down to the bj's is easy enough and you can get a good feel for them with nothing on there.
ratmonkey is offline
post #7 of 8 Old 04-14-2008, 01:22 PM
QuadraTokn
QuadraTokn's Avatar
1930 WJ
exactly.
post #8 of 8 Old 04-14-2008, 01:44 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Not necessarily. You cannot say its the ball joint if it wiggles while holding at noon and 6. It could just as easily be the hub.
Best thing to do is have someone else wiggle the tire while you watch where the slop is being introduced. If its bad enough, it will be obvious.
Something else that can sometimes help diagnose a bad hub - try rotating the tire by hand and see if you feel or hear anything abnormal.
Wheelin98TJ is offline
Front ball joints FlipFlop425 ZJ Grand Cherokee Forum 18 03-21-2009 12:11 PM
Ball Bearings? Greeeeenberg ZJ Grand Cherokee Forum 8 12-13-2008 07:50 PM
Bag of ball bearings rxl ZJ Grand Cherokee Forum 8 08-11-2007 09:24 PM
Front End Noise, Tie Rod Ends?? Steering Damper?? Ball Joints?? jimib4141 ZJ Grand Cherokee Forum 12 03-03-2007 04:44 PM
ball joints Yardman Harry ZJ Grand Cherokee Forum 3 09-25-2005 11:40 AM
