Bad front end whine - Page 2 - JeepForum.com
post #16 of 20 Old 08-21-2013, 12:27 PM Thread Starter
Adam86
Yes l did mate. Noise went away.
Adam86 is offline
post #17 of 20 Old 08-21-2013, 12:38 PM
DickDickle
So I guess that front shaft was not as solid as you claimed it was the joint on the tcase side goes bad on those and its very hard to tell with the shaft in, get a used shaft from a junk hard like I said I had the same problem mine would sound horrible under load and go away when off throttle I got a used shaft from the local junk yard and all my noise was gone
DickDickle is offline
post #18 of 20 Old 08-21-2013, 12:55 PM Thread Starter
Adam86
It seemed ok to me lol. A shaft is cheap enough so ill give it a try.
If it is the bearings would the noise remain when l remove the shaft?
Adam86 is offline
post #19 of 20 Old 08-21-2013, 01:20 PM
DickDickle
In most cases yes, I forget if you mentioned it but what tcase do you have if you have the 249 the noise would be gone with the shaft out not putting power to the front axel but if you have the 231 or 242 and drive around in 2wd and the noise was there with the shaft in and now is gone you should not have any axel issues imo
post #20 of 20 Old 08-21-2013, 03:14 PM Thread Starter
Adam86
Yeh I have a 249. Bloody thing lol
Adam86 is offline
