Bad front end whine - JeepForum.com
post #1 of 20 Old 08-04-2013, 11:08 AM Thread Starter
Adam86
Bad front end whine
Getting quite bad now. Front end is whining quite loudly but only when on the throttle. Pretty much silent when off the throttle.
Where should l start?
4.0 & 249 but l think its the front axle. LSD in the rear.
Adam86 is offline
post #2 of 20 Old 08-04-2013, 11:11 AM
DickDickle
How is your front drive shaft? Check all the joints for play, you could even take it out and go for a ride and if the noise is still there obviously not the problem, there are only 8 8mm bolts that hold it in.
DickDickle is offline
post #3 of 20 Old 08-04-2013, 11:14 AM
zj97ltd
If it's only when applying power it might be in the diff. I'd wiggle the pinion (input) shaft and see if there's any slop. Usually this is accompanied by a leak because the loose pinion shaft messes up the seal. If it's the carrier bearings you'll have to pull the cover to investigate. Hub bearings are a common failure too but from my experience, they'll make noise at speed regardless of whether you're giving it power or not.
zj97ltd is offline
post #4 of 20 Old 08-04-2013, 11:19 AM Thread Starter
Adam86
I was going to try removing the shaft but then it only does it when im on the throttle. So can't see it making a noise without the shaft anyway.
Just being out to check the shaft and its got no play. Feels solid.
Adam86 is offline
post #5 of 20 Old 08-04-2013, 11:21 AM Thread Starter
Adam86
From what's being posted im thinking carrier bearings.
When l pull the cover where and what am I looking for?
cheers.
Adam86 is offline
post #6 of 20 Old 08-04-2013, 11:29 AM
zj97ltd
Grab the ring gear and see if you can wiggle it side to side.
zj97ltd is offline
post #7 of 20 Old 08-04-2013, 11:33 AM Thread Starter
Adam86
What's the ring gear?
Can you tell I've never had an axle apart lol
Thanks for your help.
Adam86 is offline
post #8 of 20 Old 08-04-2013, 11:39 AM
zj97ltd
Sorry lol. It'll be obvious when you pull the cover off. You'll see the teeth running perpendicular to the ground. Grab hold of it and try wiggling left to right. You may have to do it with the front wheels off the ground and in neutral so that the rest of the drive line isn't bound up keeping it tighter than it may really be. Here's a pic of mine, you can see the large teeth sticking out, that is the ring gear. Inside the cover, you see to the far left and far right the bolt heads? Those are holding in the carrier bearings on each side.
zj97ltd is offline
post #9 of 20 Old 08-04-2013, 11:52 AM
DickDickle
Not true I had a bad front shaft that would make noise on acceleration sounded like a train or a bad up hill climbing roller coaster and would be quiet on deceleration. If you don't find anything in the diff try removing the shaft its not going to waste any time giving it a shot
post #10 of 20 Old 08-04-2013, 12:10 PM Thread Starter
Adam86
Thanks for the above information guys.
Just being round the block to take a quick vid. You can hear the whine stop when off the power. This was between 15-30 mph.
I assume you guys make make out the whine?
Adam86 is offline
post #11 of 20 Old 08-05-2013, 02:17 AM
shaban
Try tightening up the pinion first - it helped my whine, was getting noticable at 50+ mph. Read up on setting the pinion preload for the front axle.
shaban is offline
post #12 of 20 Old 08-05-2013, 07:51 AM
Snowfan2
Originally Posted by shaban View Post
try tightening up the pinion first - it helped my whine, was getting noticable at 50+ mph. Read up on setting the pinion preload for the front axle.
+1
Snowfan2 is offline
post #13 of 20 Old 08-05-2013, 08:51 PM
shaban
And yes, before doing anything else, change the oil. If you have visible damage on the gears or chunks of metal in oil, chances are its too late.
shaban is offline
post #14 of 20 Old 08-21-2013, 12:13 PM Thread Starter
Adam86
Had chance to take a look. Prop is fine and l had no metal in the diff oil. Everything seemed tight enough.
Are these the carrier bearings?
http://www.ebay.co.uk/itm/Dana-30-35...item27c9304923
Cheers
Adam86 is offline
post #15 of 20 Old 08-21-2013, 12:15 PM
DickDickle
Did you try driving with the front shaft out yet?
