Bad double cardan in front DS - JeepForum.com
post #1 of 27 Old 12-13-2009, 08:21 AM Thread Starter
97DCZJ
So I thought that one of my 2 u-joints in my front DS was going bad because I was getting a "chirping" noise that I had a few months back when one of them did go bad. I took out the DS yesterday, and the whole double cardan wouldn't move freely around. I had to put a lot of effort into moving it. There was no seal on the middle part (ball joint part), and it seemed that a ring was loose in there, but around the ball joint.
How can i fix this? I cannot go to autozone and buy a whole new DS for 350, and it has the CV joint part on the DS near the diff.
I'm going to just put some grease in it for now to hopefully quiet it down a bit. It chirps like crazy and I can hear it doing about 35 mph.
1997 Grand Cherokee Orvis: V8 5.2L, stock.
(Sold) 1998 Cherokee Sport: 4.0L I6, Stock.
(Sold) 1990 Cherokee: 4.0L I6, 4.5" Lift, 33" BFG's.
(Sold) 1997 Grand Cherokee Limited: V8 5.2L, 2" BB, 31" Dick Cepeks.
(Sold) 1999 Grand Cherokee Laredo:
; V8 4.7L, Stock.
(Sold) 1996 Grand Cherokee Laredo:
; V8 5.2L ,3.5" lift, 32" Tires
97DCZJ is offline
post #2 of 27 Old 12-13-2009, 08:25 AM
biggoofy
wow that sucks man
Zack
13 JKU Stock
93 ZJ F/R Long Arms, 4.56 gears
96 ZJ HP44 / 9" (RIP)
biggoofy is offline
post #3 of 27 Old 12-13-2009, 09:09 AM Thread Starter
97DCZJ
so i found this on CL - 1996 Jeep Grand Cherokee Transfer Case w/ front driveshaft
if I offer some money for just the DS, would that double cardan be the right size? Will the driveshaft maybe even just swap right in? I'll offer him $20 for it.
; V8 4.7L, Stock.
97DCZJ is offline
post #4 of 27 Old 12-13-2009, 09:21 AM
Boodyrider
You can also take the shaft to a driveline shop for repair/rebuild, or do it yourself. SEARCH. There are numerous thereads on driveshaft rebuild , some iin the last week.
97 TJ Sport - 4.0/HP D30 w ARB/8.8 w LS/4.88s; 35s and flat fenders on 2.5 lift
84 CJ7; frame off restoration in progress.
The technical advice you get from me here is worth exactly what you paid me for it. Warranty issues will be reimbursed at double what you paid me for the advice.
Boodyrider is offline
post #5 of 27 Old 12-13-2009, 09:22 AM
bigbill888
The one on craigslist probably has issues, too. Lube yours up and run with it.
bigbill888 is offline
post #6 of 27 Old 12-13-2009, 09:22 AM Thread Starter
97DCZJ
will that last long though?
; V8 4.7L, Stock.
97DCZJ is offline
post #7 of 27 Old 12-13-2009, 10:08 AM
_Kyle_
_Kyle_'s Avatar
When mine went, I went to a junkyard and bought one for $75. Said it had 100k on it and was warrantied for 1 year.
-Kyle
1996 Grand Cherokee
2005 Wrangler Rocky Mountain Edition
RIP Troy (bigbluezj94)
_Kyle_ is offline
post #8 of 27 Old 12-13-2009, 10:15 AM Thread Starter
97DCZJ
a whole driveshaft?
; V8 4.7L, Stock.
97DCZJ is offline
post #9 of 27 Old 12-13-2009, 10:23 AM
Tiggerrrrr
Can't you just rebuild it? I think I remember seeing a thread on it last year.
Edit: Found it: http://www.jeepforum.com/forum/f13/d...w-pics-480311/
'95 ZJ Limited 4.0
2.25" BB , 31 10.5 15 Treadwright MTG's on Black Rock steelies
Everything "pimpin' Gold" REMOVED!
Looking for a REAR tow hook and bracket!
Tiggerrrrr is offline
post #10 of 27 Old 12-13-2009, 10:28 AM
250psd
Check Ebay. I bought a pinion yoke from a TJ for $12 and a double cardan X u joint driveshaft from a GC for $60.
Everything bolted right up. I have a 249 TC.
250psd is offline
post #11 of 27 Old 12-13-2009, 10:31 AM
99TJSahara
Just re-do yours mine took me 2.5 hours and a busted thumb(I use the hammer and socket method) use this as a guide, same applies for ZJ, I believe:
TJ Front Drive Shaft CV Maintenance
-Joey
04 Grand Cherokee Overland
-sold
99TJSahara is offline
post #12 of 27 Old 12-13-2009, 10:34 AM Thread Starter
97DCZJ
hmm. seems pretty decent. Do you think I might be able to buy these parts at pepboys, autozone, or even napa? i believe the closest driveshaft shop near me is miles away.
; V8 4.7L, Stock.
97DCZJ is offline
post #13 of 27 Old 12-13-2009, 10:36 AM
Tiggerrrrr
I'm sure napa would either have them or could have them the next day.
'95 ZJ Limited 4.0
post #14 of 27 Old 12-13-2009, 10:48 AM Thread Starter
97DCZJ
would the part numbers be the same as from that write up to napa?
; V8 4.7L, Stock.
97DCZJ is offline
post #15 of 27 Old 12-13-2009, 10:53 AM Thread Starter
97DCZJ
I work down the street from Napa, so tomorrow I'll be taking a drive down there.
So the list goes as what I should be buying -
Spicer ball centering kit
2 U-joints
CV repair Kit
is that all?
the repair seems pretty easy
; V8 4.7L, Stock.
97DCZJ is offline
Stock Double/Single Cardan Front Driveshaft FirefightinWJ ZJ Grand Cherokee Forum 6 12-08-2009 01:49 PM
WJ caster with front double double cardan DS doublejz ZJ Grand Cherokee Forum 3 07-30-2009 10:48 AM
front driveshaft double cardan? arsonist_bob ZJ Grand Cherokee Forum 12 03-21-2009 05:33 PM
Double Cardan front shaft --- Stock on 93 ZJ? CLNinja ZJ Grand Cherokee Forum 19 12-25-2007 08:59 PM
Double Cardan Front Drive Shaft Phil Gerard ZJ Grand Cherokee Forum 19 01-19-2006 03:10 PM
