Bad Coolant Sensor, and Rear Brake light failure :( - JeepForum.com
post #1 of 8 Old 12-02-2008, 06:42 PM Thread Starter
JackedUPzeejay
Today was going good. Did a few good things to the jeep
New battery, new tranny pan gasket, new tranny filter
Then the stupid on board diagnostic thing was beeping COOLANT SENSOR BAD, and BRAKE LIGHT FAILURE.
I checked all the lights in the back, even the license plate bulbs. It will only blink and beep once I tap the brake pedal. Then the rear indication lights on the on board thing will start blinking.
and for the coolant sensor. Which one and where is it??
Thanks for any help
96 Grand Cherokee I6, 3.5" IRO lift, 31x10.50 MT/R re-treads, KOR Roof mount light bar, 4 100w lights, Factory Tow hooks, Hitch w/d-ring recovery shackle
06 Kawasaki Ninja ZX6R, All done up track bike
1999 Dodge Durango, V8, 6 inches of lift, 33"s, lockers, 8 passenger trail rig!!
JackedUPzeejay is offline
post #2 of 8 Old 12-02-2008, 06:57 PM
-Joe-
-Joe-'s Avatar
Thanks for any help
Probably your VIC.. They are prone to display messages and beep.
but the message is for the "coolant LEVEL sensor"
Cleaning it MAY help if the VIC isnt bad..
- Joe -
'95 Jeep Grand Cherokee Laredo I6 4.0L
242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs
Moog Cargo Control Springs
Magnaflow Converter - Dynomax Muffler
235/75/15 AT Uniroyal Liberator Tires
-Joe- is offline
post #3 of 8 Old 12-02-2008, 06:59 PM Thread Starter
JackedUPzeejay
Will do. What about the one that is mounted into the head? Isint that called a coolant sensor also?
post #4 of 8 Old 12-02-2008, 07:44 PM
ZJPunk98
yeah the one on the head is the coolant temperature sensor. I was getting the some message and replace the temp sensor first, didn't solve the issue. Next I replaced the one in the reservoir and this fixed the issue.
Erik
98 ZJ 5.2L JGC Limited Sold
02 4.7L HO JGC Overland
ZJPunk98 is offline
post #5 of 8 Old 12-02-2008, 07:54 PM
-Joe-
-Joe-'s Avatar
Theres 3 coolant sensors. The ONLY one monitored by the VIC is the level sensor in the overflow tank.
- Joe -
-Joe- is offline
post #6 of 8 Old 12-02-2008, 10:18 PM Thread Starter
JackedUPzeejay
Thanks Joe.
post #7 of 8 Old 12-02-2008, 10:19 PM Thread Starter
JackedUPzeejay
Anything for my rear brake light failure?
Its really annoying.
post #8 of 8 Old 12-02-2008, 11:49 PM
sadass
wow! nice diagrams Joe. looks like you tore that motor down before.
5NineZJ,35mtr/k IRO 7" LA F/R Detroit F/HP-4.56 R/Aussie 44A. ARB Snorkel/JRC Sliders/ Protofab w/9500S./Bushwhackers. Novak242 TCcable.
sadass is offline
FED UP with this stupid brake light failure thing JackedUPzeejay ZJ Grand Cherokee Forum 2 12-14-2008 06:35 PM
Brake light failure indicator tomc585 ZJ Grand Cherokee Forum 8 09-28-2008 08:30 PM
Coolant Sensor Failure on VIC Scottso699 ZJ Grand Cherokee Forum 2 05-17-2007 08:41 PM
Coolant sensor failure HarleyTyson ZJ Grand Cherokee Forum 3 10-26-2006 11:41 PM
Coolant sensor failure HarleyTyson ZJ Grand Cherokee Forum 15 07-02-2005 10:10 AM
