Bad alternator causing Transmission code? - Page 2 - JeepForum.com
post #16 of 25 Old 06-26-2013, 09:17 AM Thread Starter
brewcity1
Originally Posted by exmilitary View Post
Did you try charging the battery up first to see if the truck shifts out of first gear?
Solenoids and electronics act funny when the voltage is to low.
I agree with the other poster here; check the battery sensor.
Thanks...I put in a new battery and alternator last night...so where is the battery sensor on the 5.9L? I never heard of that.
2004 Grand Cherokee Limited 4.7L
General Grabber AT2's 255/65/17
1" Addco rear sway bar
brewcity1 is offline
post #17 of 25 Old 06-26-2013, 11:04 AM Thread Starter
brewcity1
Update
Hey guys...mechanic said the PCM is fried.
I just ordered a new one...should be here by Friday.
I'll keep you all posted...and thank you to everyone for ALL your help and advice. I just hope this does the trick!
post #18 of 25 Old 06-26-2013, 11:19 AM
98ZJOKC
Bottom of the battery tray - have to remove battery to see it. That's one of the reasons I mentioned it as suspect because you had recently had the battery replaced and it might have been damaged or been disconnected.
98ZJOKC is offline
post #19 of 25 Old 06-26-2013, 11:32 AM
zjosh93
If you just had your cat replaced did they weld it in? Welding on the exhaust without disconnecting the battery can fry the PCM.
zjosh93 is offline
post #20 of 25 Old 06-26-2013, 12:07 PM Thread Starter
brewcity1
OHHHH NOOOOOOOOO!!! Yep...just had my cat and muffler replaced. They did weld the new one on...thats gotta be it! They fried the PCM by not disconnecting the battery!
post #21 of 25 Old 06-26-2013, 02:51 PM
exmilitary
Sorry to hear that. I hope the new one works. Did I read that right that someone welded the cat without disconnecting the battery?
Any good welder knows better then that.
I know the pcms can cost a lot of money
If it is not to late, I whould go back and give the guy s**t for this. .
exmilitary is offline
post #22 of 25 Old 06-26-2013, 02:58 PM Thread Starter
brewcity1
I am actually really thinking about that! They are a great muffler shop, and I have taken my previous Jeeps there without any issues...but this time its costing me a lot in time, money, and sanity!
I actually found a PCM for $235 shipped...so its not too too bad. Better than the $600-$800 the dealerships across the country want if they have it on hand.
I just hope that this fixes everything! I'll let you all know.
post #23 of 25 Old 06-27-2013, 03:00 PM
exmilitary
That's a good deal for a pcm. Up here they are more then 800.00 dollars. Keep me posted. Pm me if you want.
post #24 of 25 Old 06-27-2013, 03:08 PM Thread Starter
brewcity1
Yeah...the one from the dealership was $795.
I will definitely keep you posted on whether or not this fixes my issues.
Thanks for all the help!
post #25 of 25 Old 07-02-2013, 08:04 PM Thread Starter
brewcity1
Update
Hey guys...got my 9er back today. All is good!
The new PCM fixed the issues...voltage back at center...fired right up...ran very strong all the way home!
Just wanted everyone that helped out to know what fixed the issues.
Thanks to everyone for ALL the help.
