backup light switch - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > backup light switch
Poison Spyder from CCOR!REPLACEMENT SOFT TOP SALE AT BASELINE 4x4 OUTFITTERS - 88-2001 - 2004 Jeep Grand Cherokee Power Window Regulator wit
Unread 07-10-2004, 07:05 AM   #1
kocka80
backup light switch
Hi all
can anyone tell me where can I find a bacup light switch on my 96 grand cherokee laredo couse none of the backup lights working
I looked everywhere but I can`t find it .even I was looking at this other thread but that is only for a 93 GC . Mine is an allwheel drive autotranny straight 6 cylinder .
thank you in advance
kocka80 is offline   Reply With Quote
Unread 07-10-2004, 10:25 AM   #2
greasefingers
1994 ZJ
Read the "Sticky" FAQ (Frequently Asked Questions)
At the top of this Forum.
Cheers Steve
Trained Professional Crack-pot
Go RU & WVU Football Teams
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
03 4Runner V8 (my wife's car)
94 Volvo 850 (my 16-yr old daughter's car) Five cylinder
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline   Reply With Quote
Unread 07-10-2004, 01:04 PM   #3
kocka80
as I mentioned in my first tread I did that and mine is simply not there and that one was a 93 GC mine is 96. but thanks for the reply.
"This only applies to the 1993 4.0L with the AW4 automatic transmission"
anyone else ??
Unread 07-11-2004, 05:08 PM   #4
kocka80
no such a luck with this tread I guess
Unread 07-12-2004, 09:55 AM   #5
kocka80
Oke people here is the deal.
The backup light switch is located on the `96 Jeep Grand Cherokee just right above the edge of the transmission pan on the drivers side .there is three wires hooked up to it.
To check if your switch is bad simply connect the two outer wires together with a paper clip or a piece of other wire,then turn the ignation on and look at the backup lights ,if they are on that means that probably(99%)switch itself is bad need to replace .Of course you need to check the lightbulbs and fuses first.
and now I have to go out there and fix mine .
good day every body!!
Unread 07-13-2004, 03:46 PM   #6
kocka80
update
oke guys I did replace this switch.
what you need is:
-1 or 2 court of tranny fluid
-oil drainpan
-1" socket does not have to be deep
- quick hands
here is how it went : the switch is just a simple screw in switch so it`s easy to unscrew with the 1" socket . now when yuo take the old one out you have to have the new one real close becouse soon as u take the old one out the tranny fluid is gonna start to run out . be quick couse if you`re not you lose lots of fluid. screw the new in and make it tight .(no specs on that one) now when I had to put the connector back on I had to use a small hammer couse I could not push it back on.
NOTE : if you want to change the tranny fluid and filter by yourself
you can drain most of the fluid right thru there and then take the tranny pan off. I dont have a drain plug on mine so this comes pretty handy.
this was done on a `96 Jeep GrandCherokee Laredo , allwheel drive , automatic , 4.0 inline 6 cilynder
