Backspacing - JeepForum.com
post #1 of 15 Old 02-21-2008, 11:41 PM Thread Starter
jhashagen
Backspacing
Tried searching but no luck. I currently have stock 17" wheels w/ 32X10.5 BFG AT's. Im putting on a COR 6" LA soon and was thinking of getting 33's and new wheels or just new wheels with less backspacing. First question is whether 17X8.5 wheels with 4.5 backspacing would work with my current tires and/or possibly with 33X11.5? Do I need less backspacing (4.0) and are 8.5" wide wheels too wide?
last question is 33X11.5 tires or 12.5" wide tires?
jhashagen is offline
post #2 of 15 Old 02-22-2008, 09:32 PM Thread Starter
jhashagen
no luck..no help? The wheels are Predators(machined) ATX series from American Racing.
post #3 of 15 Old 02-22-2008, 10:31 PM
FPKites
ZJjazzyJim
FPKites's Avatar
Everything I've read has said to use a 3.75"-4" BS rim. I think that would be the way to go, but I couldn't be absolutely sure since I haven't experienced it first-hand.
Jim Karlin
"Duh! Big RED Jeep!!!"
or
96 ZJ Laredo
5" lift, Claytons, KOR radiator support, rear bumper, steering brace, etc, etc, etc.
04 WJ Overland
Clean.... :D
FPKites is offline
post #4 of 15 Old 02-22-2008, 10:34 PM
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
the wider the tire the better.
hard working private first class in the United States Marine Corps.
Originally Posted by shift_grind View Post
It's threads like this that make me wonder why people lift there jeeps
its comments like this that make me wonder why some people are jerks.
build thread:
5.9 ANDY is offline
post #5 of 15 Old 02-22-2008, 11:12 PM
CLASH
CLASH's Avatar
I personally like a narrow tire. right now I'm running 32x11.50 with 4.5bs. with no issues as far as rubbing. next time I'm gunna go to 33x10.50.
95 zj, 4.5", 32" bfg at, locked rear.
CLASH is offline
post #6 of 15 Old 02-23-2008, 01:29 AM Thread Starter
jhashagen
any thoughts on black wheels or the machined look?
post #7 of 15 Old 02-23-2008, 09:19 AM
silentbob21
I have black soft 8s on mine, love the look. I ran into issues with 4" BS with a 15" wheel you should be fine though with a 17.
-Aaron
2004 WJ SE 4.0L I6, NV242, IRO 6.5 LAs D44a Spartan locked, 4.88s, BFG KM2s 35/12.5/15
silentbob21 is offline
post #8 of 15 Old 02-23-2008, 09:29 AM
ajmorell
ajmorell's Avatar
Are you looking for aluminum or staying with steel. I personally like aluminum wheels a lot more than steel.......even though I'm running steel wheels right now.
ajmorell is offline
post #9 of 15 Old 02-23-2008, 01:45 PM
CLASH
CLASH's Avatar
im partial to black steel
CLASH is offline
post #10 of 15 Old 02-23-2008, 04:19 PM Thread Starter
jhashagen
Planning on aluminum. either machined finish or teflon. the page from AR http://www.americanracing.com/browse_atx.asp
post #11 of 15 Old 02-23-2008, 04:31 PM
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
why would you want a narrow tire? the more rubber you put on the ground the better the traction.
build thread:
5.9 ANDY is offline
post #12 of 15 Old 02-23-2008, 04:40 PM
FPKites
ZJjazzyJim
FPKites's Avatar
Narrow tire will dig through the snow and find the pavement a bit faster is what I've read.
Jim Karlin
or
96 ZJ Laredo
04 WJ Overland
Clean.... :D
FPKites is offline
post #13 of 15 Old 02-23-2008, 06:58 PM
CLASH
CLASH's Avatar
i just like narrow tires, also less rolling resistance on the street
CLASH is offline
post #14 of 15 Old 02-23-2008, 07:28 PM
SpeedyCat3
Survivor
SpeedyCat3's Avatar
I will be looking a backspacing soon to get the adpters I need.
I am figuring a total of 3.75 BS with a shallow rim and a spacer should be fine.
The new wheels seem to be at least 5 inches BS.
I did not get a chance to measure them when I picked them up today, and It is too damn dark already.
They are a full 1/2 inch taller than my Bighorn tires, and probably a full inch wider. Flavor is 33/12.50/17 Claws.
Any suggestion on total backspacing so I can start planning?
_o o o o_
|_Jeep_|
(OlllllllO)
[] ---o-[]
SpeedyCat3 is offline
post #15 of 15 Old 02-24-2008, 08:27 AM
ajmorell
ajmorell's Avatar
Narrow tires have a lot of benefits actually. First, like Jim said, on-road in the winter they handle much much better due to less surface area in contact with the road. Narrow tires also weigh less, meaning it will cause less stress on your axles and drive train, and also better mileage.
ajmorell is offline
how much backspacing? junior214 ZJ Grand Cherokee Forum 6 09-08-2008 03:55 PM
backspacing muckcityjeep ZJ Grand Cherokee Forum 4 08-23-2008 12:07 PM
Backspacing Q Kruzin ZJ Grand Cherokee Forum 8 03-16-2008 05:35 AM
backspacing 93laredo ZJ Grand Cherokee Forum 2 01-11-2008 10:08 PM
Backspacing rowdy1 ZJ Grand Cherokee Forum 4 12-16-2004 10:06 PM
