backing up, reverse slightly revs but no movement - JeepForum.com
post #1 of 2 Old 03-12-2004, 04:50 PM Thread Starter
rerun07
i have a 1993 Grand Chreokee Limited 5.2L with 73k miles. When I am parked in a stall and want to back out sometimes, the engine would rev and not move. In order to fix this, I need to put it in drive and roll forward a bit (1-3 inches) and then put it back into reverse and reverse would work fine. Think this is a major problem? Since I don't reverse too often, the fix doesn't bother me.
Another problem I have is, in the morning right when i am about to take off from a parallel space, i just put it in drive and go. I get into drive and i feel the transmission engage, but when i step on the gas, it feels like MAJOR slippage or really sludgy.. that's the best i can describe it.
Thoughts welcomed!
rerun07 is offline
post #2 of 2 Old 03-14-2004, 09:10 AM
Stocker
It may just be low on fluid. Check hot, on level ground, idling in neutral, not in park. Very important, as checking in park can show full and still be down a quart or two.
1995 5.2 ZJ Sold... but still in the family
Stocker
Stocker is offline
Revs up/down on take off. nate13 ZJ Grand Cherokee Forum 0 09-15-2009 05:02 PM
Tie Rod movement question RyanSBenson ZJ Grand Cherokee Forum 3 07-26-2009 05:30 PM
driveshaft movement CMARJEEP ZJ Grand Cherokee Forum 11 03-01-2008 09:52 AM
Is this movement normal? jeepnurse ZJ Grand Cherokee Forum 3 04-25-2007 05:40 AM
differential movement 99GrandCher ZJ Grand Cherokee Forum 9 03-23-2006 07:22 AM
