Back windows go down, not up. - JeepForum.com
post #1 of 10 Old 06-22-2014, 12:48 PM Thread Starter
ROFLwaffles
Help. 98 Niner.
Both back windows having the same issue. They roll down and up from my switches up front. But will only roll down from the back door switches, not up. I would normally think bad switch, but they both do the exact same thing. Child locks are off, and so is the window lock button up front. What are the chances that both switches have the exact same fault? Any ideas?
Or is there something obvious I am missing?
ROFLwaffles is offline
post #2 of 10 Old 06-22-2014, 02:06 PM
xcaliber81
Check the door harnesses for broken wires, thats all I got.
xcaliber81 is offline
post #3 of 10 Old 06-22-2014, 03:27 PM
dodge16vrt
Could be the switches. Check for power going both direction at the window motor. If it is more than one window it could be the master switch.
dodge16vrt is offline
post #4 of 10 Old 06-22-2014, 04:14 PM
tirus89
+1 for checking door harnesses! I had the same issue with the driver side rear door. A bunch of the wires were broken and shorting/grounding with each other. Checked the other doors while I was at it, and 3 of 4 doors had broken wiring. Redid the wiring, and everything is legit now.
tirus89 is offline
post #5 of 10 Old 06-26-2014, 05:18 PM Thread Starter
ROFLwaffles
Both wire harnesses and the wires inside are in good shape. They are both getting power as well. I am flummoxed.
post #6 of 10 Old 06-26-2014, 05:27 PM
tirus89
Did you check the harness inside the door, or inside pillars? You can swap the rear door switches to check the switches.
tirus89 is offline
post #7 of 10 Old 06-26-2014, 05:34 PM Thread Starter
ROFLwaffles
Checked the harness going from the pillar into the door. Both are great. Like I said, if it were just 1 door, it wouldn't be strange. It's the fact that booth doors do it and everything seems to look and test fine that has me frustrated. Maybe I'll just buy new switches and see if that does it. It COULD be (pretty weird if so) that both switches have the exact same problem.
post #8 of 10 Old 06-26-2014, 05:43 PM
tirus89
Snag one from the junkyard, cheaper than buying new. And sorry, I thought only one window was malfunctioning.
tirus89 is offline
post #9 of 10 Old 06-26-2014, 06:23 PM
jeepjeepster
Wonder if a broken wire in the front door could hinder both rear windows inop?
I had something odd happen in my 94 zj the other day. Its only happened once but Im sure it will be back. The rear drivers window just up and stopped working, wouldnt do a thing. Either from the rear switch or the front. Drove a little ways and it started working again. Been fine for days...
1994 ZJ-I6 w/216,000 mi
1998 ZJ 5.9 w/65,155 mi Slate Black
2004 KJ w/90,300 mi
jeepjeepster is offline
post #10 of 10 Old 06-27-2014, 04:01 PM
chich
Had issue where passenger rear window would only go down,turned out to be broken wire in boot on driver door.
chich is offline
