Back up lights still dont work. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Back up lights still dont work.
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineBuild your Dream Jeep with Poison Spyder's Interactive GarRuffStuff Memorial Day Sale!
Unread 10-10-2011, 01:26 AM   #1
BenHinz27
Hey everyone. I post before asking about my back up lights not working. I replaced the NSS like everyone said but it still didn't work. Any ideas?
-Ben
BenHinz27 is offline   Reply With Quote
Unread 10-10-2011, 07:45 AM   #2
KoreaZJ
1994 ZJ
Do all your other lights work normally?
Is the problem unique to only BOTH backup lights?
Have you checked the obvious - blown bulbs?
Do you have a 12 volt circuit tester?
KoreaZJ is online now   Reply With Quote
Unread 10-10-2011, 10:32 AM   #3
BenHinz27
I have checked the bulbs and it is both sides and I do have a 12v
-Ben
Unread 10-10-2011, 11:01 AM   #4
MAUSS
Where have you got 12V? It should only be present on the BR/LG wires to the lamp sockets... the Black wires are ground.
'93 Limited, '96 Laredo (daughter's)
MAUSS is offline   Reply With Quote
Unread 10-10-2011, 12:37 PM   #5
ratmonkey
Living dead mod
ratmonkey's Avatar
and the nss completes the ground to the back up light circuit. power should be present with key on.
ratmonkey is offline   Reply With Quote
Unread 10-10-2011, 10:13 PM   #6
KoreaZJ
1994 ZJ
There's a plug under the driver's side REAR seat. My '94 has the stock amp under there and the plug is located forward, under the front edge of the carpet. Plug has 16-pins, 2 rows of 8 pins. Pin #14 wire going in/out both sides should be colored (BR/LG) BROWN with a LIGHT GREEN tracer stripe. Should be the only wire with these colors.
_Plug Pinout_
1 / 9
2 / 10
3 / 11
4 / 12
5 / 13
6 / 14
7 / 15
8 / 16
Using your 12 volt tester, check for 12 volts on Pin #14 while in reverse with the ignition switch on. You can either probe the back of the pin, or just carefully prick through the plastic wire coating with the tester, just enough to touch the wire inside. Make sure the tester ground clip is connected to bare metal (no paint) for a good ground.
If you DO have 12 volts on Pin #14, there's not much else further back that is common to both lamps. There's a wire splice over the the passenger side rear fender well. Think the trailer tow wires splice in here. If splices get wet, they corrode and often lose connection. Happened to my driver's side power seat.
If you DO NOT have 12 volts on Pin #14, then your problem is forward towards the instrument panel.
