axles? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > axles?
Super Low Prices on TJ Bumpers and $399.95 Tire Carriers!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGenright at JeepHut
Unread 07-02-2009, 10:03 AM   #1
GrandChe89
axles?
I have a 96 Grand Cherokee and I have the stock axles, what axles does it come with stock? How can you tell what type an axle is? I wanted to go to the junk yard eventually and get d44 front and rear axles. What is involved when you swap them out? do you have to change anything else? Any and all advice on axle swapping and buying would be greatly appreciated.
thanks
Kyle
GrandChe89 is offline   Reply With Quote
Unread 07-02-2009, 10:13 AM   #2
CLNinja
you most likely have a D35
D44a
D35
[color="#003300"]Matt[/COLOR]
[color="white"][CENTER][size="1"]
[url="http://www.jeepforum.com/forum/showthread.php?t=434081"][color="white"]Click Here For My Build Thread[/COLOR][/url]
[/COLOR][/SIZE][B]**September 2009 Grand Cherokee Of The Month**[/B]
[SIZE="2"][url="http://www.jeepforum.com/forum/forumdisplay.php?f=123"][color="white"]Colorado Jeep Club Member #88[/COLOR][/url][/SIZE][/CENTER]
CLNinja is offline   Reply With Quote
Unread 07-02-2009, 12:52 PM   #3
Jones
Consider the following...
Jones's Avatar
thanks
Kyle
You most likely have a Low Pinion Dana 30 in the front and a Dana 35 in the rear with 3.55 gears both open diff.
Swapping in Dana 44's front and rear that aren't set up for a Grand Cherokee can be quite a bit of work, they won't be bolt it.
If you want bolt in go with an HP30 and D44a. Both are stronger than what you have now.
Put your bacon where your mouth is!
Jones is offline   Reply With Quote
Unread 07-02-2009, 01:16 PM   #4
GrandChe89
[QUOTE=-
If you want bolt in go with an HP30 and D44a. Both are stronger than what you have now.[/QUOTE]
How do you tell the difference between the axles? do they just look different? or do they have some kind of mark on them so I can tell?
and what is open diff? and if I get the different axles they have different gearing right?
Unread 07-02-2009, 01:41 PM   #5
Jones
Jones's Avatar
The HP30 has the pinion at the top of the diff instead of the bottom. High pinion is on the right, low pinion is on the left.
http://www.therangerstation.com/tech...highpinion.jpg
Open diff means you don't have a locker or limited slip. Yes the gears will be different, the 44a will have 3.73 and the HP30 will have 3.55. You'll want to regear so they are the same.
Your biggest concern should be getting rid of the D35 though.
Unread 07-02-2009, 02:02 PM   #6
GrandChe89
should I replace the 35 with a 44a? how do you regear? is it a hard thing to do?
Unread 07-02-2009, 02:08 PM   #7
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
If you have to ask, it is a hard thing.
Why do you think you need to upgrade from your D35? What size tires do you plan on running? Is there something wrong with your D35?
ArloGuthroJeep is offline   Reply With Quote
Unread 07-02-2009, 02:20 PM   #8
GrandChe89
I want to eventually run 35s
Unread 07-02-2009, 05:01 PM   #9
Jones
Jones's Avatar
Then I would get a Hp30/8.8 or Waggy 44's.
Unread 07-02-2009, 10:25 PM   #10
GrandChe89
what is a waggy 44? Ive heard of it but not sure what it is exactly
Unread 07-02-2009, 10:41 PM   #11
indredsnake99
its the dana 44 out of a grand wagoneer
Wayne
1997 formerly GREEN now rustoleum bed lined zj 4.0 np242 bought 9/25/2008 MY 97 4.0 BUILD THREAD gone
1998 5.9l platnium zj np249 k&n sct bought 4/6/2010 MY NINER BUILD
2007 sahara 2 door wrangler stock bought 02/08/2011
Western Mass 4x4 KEVIN'S OFF ROAD IRON ROCK OFFROAD
Originally Posted by ZJones View Post
You'll learn a lot. I didn't know anything when I first joined this site either. (not sure if that's changed at all :laugh:)
indredsnake99 is offline   Reply With Quote
Unread 07-03-2009, 12:10 AM   #12
Jones
Jones's Avatar
Check my build thread, I just bought some today.
Look for an 86-91 Wagoneer for them.
Unread 07-03-2009, 06:31 AM   #13
GrandChe89
is a waggy 44 better than a d44 a? if so why?
Unread 07-04-2009, 08:29 AM   #14
GrandChe89
??? anyone know?
Unread 07-04-2009, 08:54 AM   #15
CLNinja
a D44a with a truss/skid is stronger than a waggy d44 BUT a waggy d44 has more aftermarket options allowing it ( with alot of $$ ) to be built stronger than the d44a
PLUS .... the d44a is straight bolt on.. .no fab work needed like with an 8.8 or d44
here are the specs on the d44 vs d44a vs d60 vs 8.8
Ring gear on a D44a is thicker
Pinion gear on a D44a is similar to a D60
30 spline axle shafts
Specifics:
Dana 60
Ring Gear Diameter = 9.750"
Pinion shaft Diameter = 1.626"
Ring Gear Bolt Count = 12
Pinion Spline = 29
Cover Bolt Count = 10
Dana 44 a
Ring Gear Diameter = 8.5"
Pinion Shaft Diameter = 1.625"
Ring Gear Bolt Count = 10
Pinion Spline = 29
Dana 44 Iron
Ring Gear Diameter=8.500"
Pinion shaft Diameter=1.376"
Ring Gear Bolt Count=10
Pinion Spline=26
Cover Bolt Count=10
Ford 8.8
Ring Gear Diameter = 8.8"
Pinion Spline = 30
Axle shafts = 1.32" 31 spline
