Axle/wheels make loud knocking noise on sharp turns - JeepForum.com
post #1 of 11 Old 01-18-2005, 12:21 PM Thread Starter
Gracie
My 96 Grand Cherokee Limited is suddenly making very loud knocking noises when I make a sharp turn - like into a driveway or a tight parking space - not while just driving and following the road.
I had some previous suspension issues with Death Wobble but that was fixed with a new steering stabilizer.
Is this serious? Any ideas what it might be?
TIA!!
Gracie is offline
post #2 of 11 Old 01-18-2005, 12:26 PM
WVZJ
It could be your CVs going bad they make a loud knocking/clicking noise in sharp turns when going bad.
98 ZJ 5.2, LA n Locked, 242 sye, 35's
87 MJ, 4.0, 8.8, 33's, oba
07 Ram 2500 5.9 ctd
WVZJ is offline
post #3 of 11 Old 01-18-2005, 01:25 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Gracie,
another ZJ issue is that the steering box will or could come loose from the bolts. Check them under the driver's side wheel well. Just three bolts need to be tightened. If they are loose, tighten them but don't bubba tighten them as you could strip them.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #4 of 11 Old 01-18-2005, 01:58 PM
greasefingers
greasefingers's Avatar
1994 ZJ
Do the tires skip or do you hear a horrible knocking/thumping a while you are turning into a parking spot? If so then it could be your Viscous Coupler. This only applies to Jeeps with the Quadratrac AWD system.
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #5 of 11 Old 01-21-2011, 01:18 PM
tylersjeep
1994 ZJ
i'm having the same problem on my 94 grand Cherokee v8 5.2 is knocking will i drive, I thank I have a bad U-joint but not sure, i was thank about taking out the front drive shaft, but I have a 249 with new VC and parts i dont want to burn it out. I have work Monday and cant deal with with the U-joint a the moment so can I remove the front drive shaft for a few weeks or will that burn out the VC, any help would be great.
PS I also have a bad CV joint to not sure if that causing the knocking?
tylersjeep is offline
post #6 of 11 Old 01-21-2011, 01:39 PM
Dustmuffins
Ball joints? Mine are clunking. If I crank the wheel all the way in one direction, get out and shove the top of the wheel back and forth with all my strength, my lower ball joints will clunk if I shake hard enough. It may be that for you.
Sucks because these ones are less than a year old. Right side too just like last time. I hope my axle housing isn't messed up.
Dustmuffins is offline
post #7 of 11 Old 01-21-2011, 02:02 PM
94chb
have someone twist the front drive shaft back and forth from under the jeep while you inspect the u joints
94chb is offline
post #8 of 11 Old 01-21-2011, 03:00 PM
Bigloww
1995 XJ Cherokee
Most likely CV joints as mentioned above. My 95 has been doing it for a year or so intermittently. Only at low speeds and very tight turns. Sometimes with a little jerking action, but not always. Herd it could also be the dredded Viscus Coupler as well, but not too worried about it.. With almost 180K on it and being beat on in the snow and mud a bit, it could be anything. Could also be the U joints on the front drive shaftas well, but I would guess CV or ballers.
Bigloww is offline
post #9 of 11 Old 01-21-2011, 07:17 PM
tylersjeep
1994 ZJ
will i have a bad CV axle that i've been ignoring for two years. i do not think its the VC because i replaced 5 month ago and it only has 1,500 miles on it, and it only happens when im going slow speeds. so must diffidently it has to be the cv axle because it knocking and popping at slow speeds when i turn tightly plus it hopping when i turn.
post #10 of 11 Old 01-21-2011, 08:58 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
Why did you post if you already knew the answer?
ratmonkey is offline
post #11 of 11 Old 01-22-2011, 09:06 AM
tylersjeep
1994 ZJ
because im not sure if its the cv axle or not, i know i have a bad cv but it could also be a u-joint. i'm not sure if its my transfer case and the VC because i just replaced the VC 5 months ago and it only has 1,500 miles on it, i have matching tires. it only happens at low speeds i get a knock sound, and the wheel hoops when i do a sharp turn, i did a 360 and my car was hooping. so i have no idea what is going on.
Knocking sound on sharp turns.. ldav7 ZJ Grand Cherokee Forum 6 01-17-2016 07:20 PM
Dana 44A problem, axle make noise, turns heavy. mattilacken ZJ Grand Cherokee Forum 9 09-07-2009 12:59 AM
Grinding when I make sharp turns alcahollis ZJ Grand Cherokee Forum 10 07-23-2009 06:55 PM
Sharp turns Make LOUD GRIND/VIBRA murrelldc ZJ Grand Cherokee Forum 12 02-25-2009 10:41 AM
Rear End Noise Under Sharp Turns Briandl ZJ Grand Cherokee Forum 7 03-29-2007 08:07 PM
